Well New Project time!
Jay1969
#106 PostAuthor: Jay1969 » Fri Aug 01, 2014 11:30 pm
Couldn't have chosen a better exhaust design myself :wink:
Is Vic There
#107 PostAuthor: Is Vic There » Mon Aug 04, 2014 7:55 pm
More pictures of the exhaust, I'm very happy with the results, just what I wanted :D
#108 PostAuthor: ADRIAN H » Mon Aug 04, 2014 8:18 pm
Is Vic There wrote:More pictures of the exhaust, I'm very happy with the results, just what I wanted :D
Very nice.
#109 PostAuthor: Ginger Bear » Tue Aug 05, 2014 6:37 am
Now that's what I'd call a Harris :xbou ........... Nothing like that Norman Hyde shite. :turd
# 104
Jay1969
#110 PostAuthor: Jay1969 » Tue Aug 05, 2014 9:05 am
Ginger Bear wrote:Now that's what I'd call a Harris :xbou ........... Nothing like that Norman Hyde shite. :turd
+1 :save :bla
Is Vic There
#111 PostAuthor: Is Vic There » Tue Aug 05, 2014 9:44 am
Thanks lads, I'm dead chuffed with it :hoo
Is Vic There
#112 PostAuthor: Is Vic There » Thu Aug 14, 2014 7:48 pm
Got the rear WP shock back, very happy with the job.
As you can see the hose has been replaced, all the seals and rubbers, the spring has been powder coated and the reservoir anodised.
All for 164 pounds :D
James can be contacted on, tell him I put you on to him :wink: sales@mailorderrepairs.co.uk
All the old worn out bits
Image[/img]
Is Vic There
#113 PostAuthor: Is Vic There » Sat Aug 23, 2014 10:46 pm
As you might know the engine side of this project has been a nightmare.
I couldn't get a solid mount engine down here and then bought a GPz1100 motor thinking it would fit and it didn't.
Then bought a Z1000R motor thinking it was a solid mount and as you know its not!
Neil got me a motor but it was minus the head so I ended up buying a head from a bloke on eBay US, then he offered me the block so I bought that! I thought while its in the US I might as well get the head done and the block checked and if it needs it new pistons etc! That was the plan anyway :roll:
So I contacted Joe Hooper from Pitstop a few emails latter the head and block were on their way to his shop in Orlando!
One thing led to another and I ended up getting some hot cams fitted to the head, then the block needed new pistons due to the cams! I thought I might as well buy all the gaskets and service items from Joe so got these!
Then Joe mentioned a that I'd might as well get an engine from him, we did a deal which enabled me to pay for his services over a few months, so I bought one! Well the bottom end to fit my top end!
After reading a few post on here I think I have also got the mix right for a strong motor!
The motor the Neil got me will be stripped and rebuilt, but now I don't have to rush it and can look further in to specifications!
Here's some pictures :D
#114 PostAuthor: Pigford » Sun Aug 24, 2014 6:52 am
Now that looks well schweet :twisted:
That Harris is gonna fly :rocks
#115 PostAuthor: Ginger Bear » Sun Aug 24, 2014 7:43 am
Beautiful......... Just 'plug and play'. :lon :lon
# 104
weaver
#116 PostAuthor: weaver » Sun Aug 24, 2014 8:08 am
great stuff,must be stressful doing a transcontinental build,keep up the good work :wink:
Is Vic There
#117 PostAuthor: Is Vic There » Sun Aug 24, 2014 9:18 am
weaver wrote:great stuff,must be stressful doing a transcontinental build,keep up the good work :wink:
Its all down to the people at the other end and up to now they have been really honest and very helpful.
Neil from the forum has been spot on, I know I have asked a lot from him but he has been a true diamond and ultra helpful even tho he seems to work all the time!
Steve Harris has been great to deal with and I'd fully recommend Harris.
Even down to the company I'm getting to do the powder coating, once I'd rang them and explained that I was ringing from Australia they can't do enough for me.
I just hope things continue to tick along :D
Bit of trivia, on the 28th of this month I'll have done 12 months without smoking, the money that I use to spend on cigs have paid for this engine, how mad is that :shock:
weaver
#118 PostAuthor: weaver » Sun Aug 24, 2014 9:46 am
I gave up seven years ago no way I could smoke now and do my bike,keep ploughing the money into the Harris!
Is Vic There
#119 PostAuthor: Is Vic There » Sun Aug 24, 2014 9:54 am
weaver wrote:I gave up seven years ago no way I could smoke now and do my bike,keep ploughing the money into the Harris!
Me too :bla
Is Vic There
#120 PostAuthor: Is Vic There » Wed Aug 27, 2014 12:56 am
Well the engine is making its way down here right now, very excited.
Here is the specification and what Joe does in a rebuild, basically a new engine. As you can see its been fitted with all the good bits and bobs, mark 11 bottom end, Z1000 barrels and head, should be good fun.
Joe's a good fella and I have no problems recommending him, I think a couple of people on here have also used his services?
Refinish head, in high temperature baked on silver.
Refinish cylinder, in high temperature baked on semi-gloss black.
Refinish H-cover, in high temperature baked on silver.
Bore cylinder to match piston kit supplied by PSP.
Complete valve job with new APE bronze valve guides and Viton valve seals, includes setup on the bench with all valve clearances set to Kawasaki recommended clearance for a new valve job.
PSP-3X camshaft set with .418 inch lift and 282 degrees duration at .030 inch lift.
MTC-K1075-2F complete piston kit with:
(4) 72mm forged aluminum pistons with 10.5:1 cranking compression when used with PSP-3X camshafts,
(4) sets of 72XC rings,
(4) hard chromed wrist pins,
(8) teflon buttons, sized for 72mm bore,
(1) fiber two piece head gasket, (1) chain galley center o'ring,
(1) base gasket.
APE Heavy Duty Valve Springs VSP500.
Kawasaki p/n 92003-208 hardened camshaft bolts.
APE p/n ACS900K adjustable camshaft sprockets, early 30 tooth. ACS1000K for Mark 2 bottom end.
Cometic p/n C8072 bottom end gasket kit for 1973-1980 Z1/KZ900/KZ1000, includes: oil pan, dyno cover, transmission cover, points base, points cover, clutch cover, kickstarter cover and cam chain tensioner.
APE p/n KM4811 intake manifolds for 34mm carbs, set of four.
6.0mm X 1.0mm X 16mm zinc phillips head screw.
6mm zinc flat washer.
Cometic H-cover gasket p/n C8263.
APE p/n BSO5MHx122 Tsubaki Heavy Duty roller pin cam chain with 122 pins for 1973-1978 Z1/KZ900/KZ1000. 124 for Mark 2 bottom end.
APE p/n CS900K Heavy duty cylinder stud kit.
APE p/n CHN1000K Heavy duty head nuts.
APE p/n KT1000 manual cam chain tensioner for 1973-75 Z1, 1976-77 KZ900, 1977-80 KZ1000.
APE p/n DPK900 oil drain plug.
O'ring Oil pipe 670B2018
O'ring Oil pressure switch 92055-055
O'ring Oil pump & case halves, D-shaped 92055-048
O'ring Oil pan to case 92055-052
O'ring starter snout 92055-1276
Z1E p/n KL15-2444 tach drive oil seal.
Kawasaki p/n 670B1510 tach drive 10mm o'ring.
Kawasaki p/n 670B2015 side oil plug o'ring.
Kawasaki p/n 670B2016 breather bolt o'ring.
O'ring Oil filler cap 92055-049
O'ring Oil side plug, oil pipe plug 670B2015
O'ring Crankcase breather o'ring 92055-052
Oil filter with o'rings EM10-37500
Top Cam Chain Idler Assembly, Liska P/N LIZ1TI.
APE p/n Z1BL1000 billet top idler spacer blocks.
Cam Chain Idler Sprocket, Liska P/N LIZ1I.
Rubber cam chain idler dampers, P/N 92075-232.
Roller tensioner assembly, Liska p/n LIZ1T.
Cam chain roller, bottom, P/N 12055-002.
Rubber cam chain idler dampers, P/N 92075-123.
Seal kit, KL15-8173
Allen head bolt kit, NGJ1
Refinish cases, in high temperature baked on silver.
Refinish transmission cover, in high temperature baked on silver.
Refinish oil pipe, in high temperature baked on silver.
Refinish oil filter cover, in high temperature baked on silver.
Refinish oil pan, in high temperature baked on silver.
Polish Dyno cover.
Polish Countershaft sprocket cover.
Polish clutch adjustment cover.
Polish points cover.
Polish points base.
Polish clutch cover.
Clutch cover etched with "Custom Built By Pit Stop Performance".
Polish kickstarter cover.
Polish crankcase breather.
Polish side oil plug.
Polish oil fill cap.
Early style KZ transmission refurbishment: bead blast gears, perform 14X visual inspection, undercut 33 gear dogs on 2nd through 5th gears.
Glass bead steel clutch plates and pressure plate.
Resurface cylinder.
Resurface head.
Weld Crankshaft.
Grind camshaft lobe clearance.
Remove and replace top end cylinder studs.
Install dyno cover rubber grommet.
Rebuild starter motor, turn commutator, install new brushes.
Engine build with camshaft degree, complete.
Cam chain guide, P/N PM72-065.
Intake manifolds (carb holders), 34mm for flatslides.
Wire clamp.
2 under starter motor.
2 in from bottom in case.
4 H-cover.
Ignition screw, flat washer, lock washer.
NGK B8ES spark plugs.
MTC oil pan gate p/n MIS-K339 with modified installation.
Z1E p/n RIGROMMET Dyno cover rubber grommet.
Kawasaki p/n 92083-021 (1973-1975) or p/n 92083-028 1976-2005) Shift lever return spring.
RME p/n 70-103 Starter motor brush set.
Z1E p/n MAVC149 Fiber clutch disc, set of eight.
Z1e p/n 52015-004 Oil level window.
O'ring, transmission output shaft, P/N 92055-035.
O'ring, oil pipe, 18mm, P/N 670B2018.
O'ring, starter motor housing, P/N 21027-003.
Z1E p/n AP-4001-4 OEM style cam end plugs 73-80.
Exhaust Gaskets.
KZ1000 Mark 2 donor engine complete, less head and cylinder.
Crate, plywood and pressure treated 2X4 construction, meets all international import restrictions for Europe, Japan, Australia and New Zealand.
Engine stand.
Shipping to Australia, air freight. Booked 8/25/2014 with $2000 insurance.
