Anyone got any tips for keeping Ramair filters from falling off the carbs other than superglue !
I've tried different width clips, not over or under tightening etc etc if you tighten them too much they pop off anyway.....I don't want to fit k & n's.
The carbs are 33 CR's if that makes any difference
Tips for keeping ramair filters on !
If you don't plan on ever using the velocity stacks that come with the CR's when you bought them, or don't mind buying another set,
you could cut them down to the same depth of the Ramair filter rubbers, then clamp the Ramair filters onto the cut down velocity stacks with the jubilee clips,
whilst ensuring to secure the velocity stack's on the CR's with the grey locking rings on the carb bodies.
Non standard Z900 - purchased from HIGGSPEED - http://www.higgspeed.com/ -
http://www.z1ownersclub.co.uk/forum/vie ... 6a7d5e816c
- harrythemagnum
Put your stacks on and use a pair of these over them, the spacing is correct for Zeds.
http://www.ebay.co.uk/itm/RAMAIR-PERFOR ... 5aeb307565
What a wonderful philosophy you have,
I had some RAMAIR filters on the Keihin CRS carbs on my bike.
Took it in to Debben performance for carbs to be tuned.
The RAMAIR filters took a trip to the bin.
Ray reckons very difficult tune the carbs with those filters on.
I have ended up with velocity stacks, with mesh filters over the end from Japan.WEBIKE
