cam chain idler sprocket
just a quick question. on my z1a engine one of the cam chain idler sprocket inner steel bush that holds the needle bearing slides out looks fine but is it goosed or is this normal the other one doesn't move at all.
thanks
thanks
The teeth rarely wear. It's the damper rubber that becomes hard and brittle and then fails.
If one has failed then all the others will be heading for the same fate and should all be replaced.
Liska racings heavy duty replacements are cheaper than OEM but will last much longer as they have no damper rubber to fail.
They also stock most of the other camchain tensioner components needed for a rebuild.
Here's a link to their site.
They are in the US but will ship to the UK, you just need to email them first as the site isn't set up for uk shipping.
http://www.liskas.com/servlet/the-Cam-C ... Categories
