Get out there with your tape measure.
Old man Ash's Z1000 had a RWU ZXR750 front end it worked and looked good
Pigford wrote:Hi matey![]()
I'm using Gixxer running gear (17" wheels, 120/70 front & 180/55 rear).
The 180 is a tight fit at the engine sprocket bit. The sprocket cover needed a little bit filed out to clear the chain. I'm using a 630, so a switch to a 530 would be better.
The off-set sprocket is a Debbens billet item although Talon (Yeovil) do one off stuff too.
Riding, handling & cornering all OK, so GO FOR IT
