Z1B New Petrol Filler Cap
taylor88
#1 PostAuthor: taylor88 » Thu May 29, 2014 7:22 am
Hi Guys,
I have bought a nice new petrol filler cap for the Z1B. Any pointers on how to get the 'pins' out for the cap and catch please? Hoping not to use a hammer so near the paintwork!
cheers
GTB
GTB
garyd
#2 PostAuthor: garyd » Thu May 29, 2014 7:26 am
No real trick...just find as long a 'drift' as possible and tap it out.
pertonpc
#3 PostAuthor: pertonpc » Thu May 29, 2014 8:35 am
Getting pins out -
mask off around filler neck and top of tank with heavy cloth / towel etc. over tank to prevent accidental damage. Cut a cardboard template to fit around filer neck if you want to be extra careful.
I used a drill bit of right diameter to tap old pin out (the rear pin seems to be a lot harder to release than the front one. Try tapping from both sides - always seem to come out easier one than the other I found.
Give it some release spray to soak in before you attempt it if it has been there for decades.
Re-fitting spring for catch -
hold spring closed by inserting into end of a small spade connector. This allows easier fit and then just pull the connector off to disengage when the pin has located correctly.
Hope that helps a bit. From Mark
Jay1969
#4 PostAuthor: Jay1969 » Thu May 29, 2014 8:49 am
Garn's thread on this subject may also be of help to fit the new one...
http://www.z1ownersclub.co.uk/forum/vie ... ht=#235731
taylor88
#5 PostAuthor: taylor88 » Thu May 29, 2014 9:46 am
Great advice I will give it a go later thanks very much
GTB
Users browsing this forum: Google [Bot] and 19 guests
