Hi Guys,
I have bought a nice new petrol filler cap for the Z1B. Any pointers on how to get the 'pins' out for the cap and catch please? Hoping not to use a hammer so near the paintwork!
cheers
GTB
Z1B New Petrol Filler Cap
Getting pins out -
mask off around filler neck and top of tank with heavy cloth / towel etc. over tank to prevent accidental damage. Cut a cardboard template to fit around filer neck if you want to be extra careful.
I used a drill bit of right diameter to tap old pin out (the rear pin seems to be a lot harder to release than the front one. Try tapping from both sides - always seem to come out easier one than the other I found.
Give it some release spray to soak in before you attempt it if it has been there for decades.
Re-fitting spring for catch -
hold spring closed by inserting into end of a small spade connector. This allows easier fit and then just pull the connector off to disengage when the pin has located correctly.
Hope that helps a bit. From Mark
Garn's thread on this subject may also be of help to fit the new one...
http://www.z1ownersclub.co.uk/forum/vie ... ht=#235731
Non standard Z900 - purchased from HIGGSPEED - http://www.higgspeed.com/ -
http://www.z1ownersclub.co.uk/forum/vie ... 6a7d5e816c
