rear tyre grippers
rear tyre grippers
any body know if they are still available? want some new ones for my rebuild, cant see them in marsdens part book
Bedlow1, I haven't heard these mentioned for ages! I understand they are not know required, if you are using modern tyres. So this presents a problem when restoring rims with the holes already made for them....... Do you put a couple of dummy threaded pieces in the rim, or do you double up on the rim tape, so as to avoid the rim tape "bubbling-up" and out!
- DogsbolloxofZ1B
- paul doran
