Mark II Carb problems
njwmct
#1 PostAuthor: njwmct » Sun May 11, 2014 12:39 pm
Put the Mikuni VM28SS carbs back on the Mark II today & have a problem with fuel leaking.
These are the same carbs that are fitted to the Z1R
Leaking from the fuel line T-Piece in between carbs 2&3 - had a look on the net & it appears that the part no. is 92005-1010 but no longer available - couldn't see any individual seals.
(I suspect that modern fuel has attacked the seal)
So perhaps the fuel feed joints between carbs 1/2 & carbs 3/4 may also need to be replaced - looked up the part no. 92005-1009 & these are also no longer available.
Haven't taken the carbs apart yet so don't know whether there are any seals that can be replaced ?
But wondering if anyone has had this problem & come up with fix?
#2 PostAuthor: PAULJAC47 » Sun May 11, 2014 4:02 pm
There are brass replacements that can be sourced for this,cant recollect where from though will have a dig!!!http://www.nrp-carbs.co.uk/shop/index.php?route=product/category&path=43
Here you go!!!!!
njwmct
#3 PostAuthor: njwmct » Sun May 11, 2014 4:21 pm
That's great!
Thanks for your help.
