Gaskets
Wayne1960
Gaskets
#1 PostAuthor: Wayne1960 » Sun Mar 16, 2014 2:01 pm
I have a new gasket set. Im guessing from the lack of and the stuff i have read there is no gasket between the mating surfaces of the crank case! is the correct and should i just use the gasket sealant?
Bike now finished what a joy!
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Sun Mar 16, 2014 3:42 pm
youre right no gasket,just use proper gasket stuff like kawabond or Suzuki bond (cheaper)
jimmock
#3 PostAuthor: jimmock » Sun Mar 16, 2014 4:04 pm
Or DIRKO.
Jimmock. :wnkr
I hate people I don't like !
Wayne1960
#4 PostAuthor: Wayne1960 » Sun Mar 16, 2014 4:36 pm
Ahhh now i went with what Zpower habe which is a Japanese equivalant called Michel!
surely thats ok.
Wayne1960
#5 PostAuthor: Wayne1960 » Sat Mar 22, 2014 10:01 am
Should I apply the gasket sealer to the lower or upper case and how much goes on?
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Sat Mar 22, 2014 10:47 am
Either way.
You only need a light smear if you put to much on it it will all squidge out and end up in your oil strainer blocking the pump eventually.
Wayne1960
#7 PostAuthor: Wayne1960 » Sat Mar 22, 2014 10:50 am
Thanks wackier does it go on all the flat surfaces Evan the small bits between the bearings?
malmojoe
#8 PostAuthor: malmojoe » Sat Mar 22, 2014 11:16 am
Wayne1960 wrote:Thanks wackier does it go on all the flat surfaces Evan the small bits between the bearings?
have you seen this kawasaki training video Wayne? Might be interesting. The rebuild starts at about 11mins in.
http://www.youtube.com/watch?v=BUaao5mMylU
Wayne1960
#9 PostAuthor: Wayne1960 » Sat Mar 22, 2014 11:35 am
Yes I watch it all the time and have been sticking to it religiously. But it doesn't go into this type of detail just tells you to do it! I know it probably obvious but just want to get it right.
malmojoe
#10 PostAuthor: malmojoe » Sat Mar 22, 2014 11:38 am
I agree, it's a bit like the Generation Game :lol:
Wayne1960
#11 PostAuthor: Wayne1960 » Sat Mar 22, 2014 11:50 am
Ah don't say that just as I'm about to do it! Did you ever see the couples piping the icing on the cake !!!!!!!!
wilsonsjw11
#12 PostAuthor: wilsonsjw11 » Sat Mar 22, 2014 12:02 pm
Very early Z1 engine being stripped/rebuilt in the video by the looks of the oil pressure switch housing.
Regards
Steve
