i have just started to clean up the bolts for my engine rebuild. the bolts in question are the ones the hold on the cases, cam, points, clutch ect.
I have just noticed they are all Allen bolts and when checking sizes on the parts list they are all referred to as Hex.
What is correct? and should i stick to the Allens?
Bolts
wilsonsjw11
jphaynes669
Allen key headed casing bolts are a lot more practical than the original cross / philips headed bolts. Which you have to impact drive to get out, and are a bugger to tighten up. Just my view.
If you want to be totally original, I know that Beezees Kawasaki sell replica casing bolts.
Links to Z1 enterprises
cam cover bolt set - http://www.z1enterprises.com/ItemDetail ... 003-092X16
cover JIS Screw set - http://www.z1enterprises.com/ItemDetail ... m=XBS-2000
Users browsing this forum: Bing [Bot] and 26 guests
