gpz1100 ut
snotie1965
gpz1100 ut
#1 PostAuthor: snotie1965 » Sat Feb 15, 2014 3:05 pm
I have just got the standard paint work back on my unitrak (tank warning light console) , how do i go about fitting the battery warning wire ? could a buy the part that goes into the battery ? and also where on the loom is the wire located,and what colour is the wire ? I do not want to strip back to much of the tidy loom to find it ?
Any help would be appreciated ,Andy ......
#2 PostAuthor: Ginger Bear » Sat Feb 15, 2014 3:18 pm
The wire is pink & exits the loom very close to the battery. If you connect it to +12v it will stop the warning light flashing.
It was also possible to buy the sensor that replaces one of the battery caps when I did mine, but that was probably around 4 years ago now.
# 104
garyd
#3 PostAuthor: garyd » Sat Feb 15, 2014 4:36 pm
saw one on ebay in the last few days...so they are still available.
johnA
#4 PostAuthor: johnA » Sun Feb 16, 2014 12:13 am
you can still get them from cradley kawasaki and i think wemoto might have them also.
hope this helps john
snotie1965
#5 PostAuthor: snotie1965 » Mon Feb 17, 2014 12:17 pm
Cheers for the advice lads ,
I cant find one on "Wemoto" or "evilbay" so i will ring "cradley Heath"
Thanks for your help .
Gus
#6 PostAuthor: Gus » Mon Feb 17, 2014 12:53 pm
"Set the GRINDER on it"
#7 PostAuthor: Ginger Bear » Mon Feb 17, 2014 12:53 pm
Part No. is 27010-1177
http://www.ebay.co.uk/itm/KAWASAKI-NOS- ... 0741848027
I'd try Z-Power.
# 104
Gus
#8 PostAuthor: Gus » Mon Feb 17, 2014 1:18 pm
Hi Steve.
Are you well?
I thought the part number 26012-1053 from Kawasaki.com.
http://www.wemoto.com/parts/picture/hl-705500/
Any good?
#9 PostAuthor: Ginger Bear » Mon Feb 17, 2014 1:23 pm
Hi Gus, I am well, thank you.
This is what I got from Kawasaki.com;
https://www.kawasakiepc.com/PartInfoDet ... 27010-1177
Googling the part No. seems to support the fact that it's correct. :??
# 104
Gus
#10 PostAuthor: Gus » Mon Feb 17, 2014 2:34 pm
Hmmmmm.
I'm Jimmocked
https://www.kawasakiepc.com/PartInfoDet ... 26012-1053
I think this must be a battery with a built in sensor
snotie1965
#11 PostAuthor: snotie1965 » Mon Feb 17, 2014 2:42 pm
Gus wrote:Hi Steve.
Are you well?
Any good?
That looks like it will do ? the original bit is way to much money !! otherwise i will connect up to live feed and forget about it ?
thanks again lads for your help .....
steve bowdler
#12 PostAuthor: steve bowdler » Mon Feb 17, 2014 8:49 pm
snotie1965
#13 PostAuthor: snotie1965 » Tue Feb 18, 2014 11:18 am
Gus wrote:Hi Steve.
Are you well?
Any good?
That looks like it will do ? has anyone used this type before ? if not i will go for the original kwak one £18 seems a fairish price ?
#14 PostAuthor: Ginger Bear » Tue Feb 18, 2014 12:48 pm
I have the genuine item for that price. I had a box of spares that contained a pattern sensor & it just didn't fit properly. :cry:
# 104
snotie1965
#15 PostAuthor: snotie1965 » Tue Feb 18, 2014 1:08 pm
Ginger Bear wrote:I have the genuine item for that price. I had a box of spares that contained a pattern sensor & it just didn't fit properly. :cry:
Cheers mate , that is what i will do then ! like you say "it will fit properly"
Thanks Andy .........
