What finish on exhaust baffles
G
#1 PostAuthor: G » Wed Feb 12, 2014 7:25 pm
Just got my exhaust back from refurb and was wondering what is the correct finish for the visible end of the baffle including the retaining nut and bolt was please? Also nut and bolt size would be helpful , cheers g
G
#2 PostAuthor: G » Wed Feb 12, 2014 7:30 pm
Sorry should have said it is an a4
Garn 1
#3 PostAuthor: Garn 1 » Thu Feb 13, 2014 10:25 am
G, the baffles are usually left "black" unprotected and they are usually painted in-situ, on the visible part, once they are assembled into muffler pipe.
I recall having to remove this silver paint (probably heat resistant) from the internal part of the pipe, so that the baffle will slide out, once the 6mm retaining bolt is removed.
G
#4 PostAuthor: G » Thu Feb 13, 2014 8:09 pm
Thanks again Garn. They have been returned painted silver which I thought was incorrect , as usual very much appreciated :D
#5 PostAuthor: ADRIAN H » Thu Feb 13, 2014 10:15 pm
Definitely black finish
G
#6 PostAuthor: G » Fri Feb 14, 2014 7:10 am
Thanks Adrian :D
mick znone
#7 PostAuthor: mick znone » Fri Feb 14, 2014 8:11 am
mick znone
#8 PostAuthor: mick znone » Fri Feb 14, 2014 8:12 am
G
#9 PostAuthor: G » Fri Feb 14, 2014 4:42 pm
:D
DogsbolloxofZ1B
#10 PostAuthor: DogsbolloxofZ1B » Fri Feb 14, 2014 6:12 pm
The genuine OEM were Dark Grey, sort of primer finish. The New ones are black.
G
#11 PostAuthor: G » Sat Feb 15, 2014 9:00 am
Thanks , appreciated :D
