seat catch conversion
wayno
#1 PostAuthor: wayno » Wed Jan 15, 2014 10:42 pm
i have a z1 repro seat that i need to fit the 900a4 type instead of the post type, i was hoping that there would be obvious indications as to where the new holes need to be drilled. anyone done this and found an easy way of marking out for drilling?
cheers wayne
wayno
#2 PostAuthor: wayno » Thu Jan 16, 2014 6:04 pm
got fed up waiting for an answer so had a go and sorted with some double sided foam tape
#3 PostAuthor: Ginger Bear » Fri Jan 17, 2014 7:27 am
Bloody hell wayno....... Patience obviously ain't your thing. :D
I am in the middle of doing exactly the same conversion. If you can wit 'til the weekend I'll post some pic's.
I don't think double sided tape will last long, but will work well to get it all lined up. :??
# 104
wayno
#4 PostAuthor: wayno » Fri Jan 17, 2014 8:28 am
yeah that worked well to get it lined up, now drilled and tapped and fitted. the u shaped catch has a broken leg so need to get or make another then jobs a good un :D
nw66
#5 PostAuthor: nw66 » Fri Jan 17, 2014 8:55 am
i'm doing the same also would appreciate some pics :D
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
