What is the best crankcase liquid gasket?
jphaynes669
#16 PostAuthor: jphaynes669 » Wed Jan 08, 2014 9:20 pm
jimmock wrote:DIRKO.
It was sold by DAF in the 80's.
It was sort of unique to DAF then, came in a DAF box with a DAF part number.
Now available anywhere.
It is good stuff.
Dead right jimmock, dirko is a must, use it on all my stuff.
Very good on the top hats on the back of 2500, s if memory serves me right :wink:
Jeff.H
Jay1969
#17 PostAuthor: Jay1969 » Wed Jan 08, 2014 9:39 pm
zed1015 wrote:Used to use Hylomar years ago but prefer the RTV now.
It's a better all round product for sealing cases, cam end plugs and cam chain tunnel etc.
The Hylomar is non setting so no good for the cam tunnel and the cam end plugs tend to shift and need reseating if the camcover is removed whereas the RTV stays put.
Both have the same temp rating.
Thank you Rob, I'll take your advice.
jimmock
#18 PostAuthor: jimmock » Fri Jan 10, 2014 3:11 am
It is good stuff.
I miss them old DAF's. The axle was a 2699 if I remember correctly.
They dropped the 2699 when the ATI came out.
The 2699 was still used on heavy haulage though.
I see they are back to reduction hubs on tippers again.
Dirko was a must between the timing plate and the block on the 1160's.
Jimmock. :wnkr
I hate people I don't like !
Z1parR
#19 PostAuthor: Z1parR » Fri Jan 10, 2014 7:16 pm
Jim you are clearly HGV positive :shock:
0172 . Geoff Parr
jimmock
#20 PostAuthor: jimmock » Fri Jan 10, 2014 8:12 pm
Z1parR wrote:Jim you are clearly HGV positive :shock:
I do like the wagons.
I miss them too.
Jimmock. :wnkr
