Moto Martin post classic race bike
chriskid
#16 PostAuthor: chriskid » Fri Jan 18, 2013 8:28 pm
great project love it allready!
maybe reconsider the Hagons to be replaced by a set of real shockers... :clap
Mr Puffin
#17 PostAuthor: Mr Puffin » Fri Jan 18, 2013 9:01 pm
That looks really good converted to twin shock Toyboy :) What was the arm originaly intended for XJR :?:
Toyboy
#18 PostAuthor: Toyboy » Fri Jan 18, 2013 9:53 pm
Will look at replacing the shocks at at later date.
The plan is to get it up and running 1st and see if it will handle if at all.
If anyone has ridden one of these in anger. Any feedback would be appreciated. I know there are a couple raced in 4 hr endurance races at spa and the like.
This is the Project 34 GS1000
Toyboy
#19 PostAuthor: Toyboy » Fri Jan 18, 2013 9:57 pm
Mr Puffin wrote:That looks really good converted to twin shock Toyboy :) What was the arm originaly intended for XJR :?:
Not entirely sure i think it was a yamaha xjr item. It's been modified quite a bit
Mr Puffin
#20 PostAuthor: Mr Puffin » Fri Jan 25, 2013 7:46 pm
That GS looks very nice :twisted: Are those GSXR Slabside wheels
Toyboy
#21 PostAuthor: Toyboy » Thu Feb 14, 2013 4:54 pm
Gear selector drum and fork machined to clear gpz gearbox.
Toyboy
#22 PostAuthor: Toyboy » Fri Feb 15, 2013 2:17 pm
GPZ undercut gearbox with output shaft bearing conversion
Toyboy
#23 PostAuthor: Toyboy » Sat Feb 16, 2013 3:38 pm
Heavy duty crankcase studs
[/quote]
HowieD
#24 PostAuthor: HowieD » Mon Mar 04, 2013 8:01 am
Very nice.
CD185, Maggot, Z1-R, Horace
Toyboy
#25 PostAuthor: Toyboy » Tue Dec 10, 2013 1:40 pm
Been a while bump
Not much to report. Slow burner. Mtc pistons fitted and top end on. Cams need dialling in. That'll be another 6 months gone...
Big Fluff
#26 PostAuthor: Big Fluff » Tue Dec 10, 2013 4:02 pm
Eee.. I really miss my Moto Martin. My frame cracked around the lower engine mount due to me shoving too many horses through it on the drag strip.
They do handle real sweet though, and are far more comfortable than a Harris or Rickman.
Your pistons look like they have quite a high CR on this engine you're building.?
If they're just 10.25:1 you'll be fine, but if they're 13:1 you'll need to have the liners piano wired.
Just a thought.....
Keep up with the progress reports and all the best, Will
Toyboy
#27 PostAuthor: Toyboy » Sat Feb 15, 2014 5:01 pm
Motor finished
back in chassis
#28 PostAuthor: Pigford » Sat Feb 15, 2014 5:24 pm
Phwaaaaaaaaaaaaaaaaaaar :twisted:
neilbarrett
#29 PostAuthor: neilbarrett » Sat Feb 15, 2014 5:25 pm
motor looks well,
Toyboy
#30 PostAuthor: Toyboy » Sat Mar 22, 2014 11:50 pm
Nearly finished. A couple of small jobs to do.
