I'm helping another fellow Z1OC member (Will Noble) sort out the back end on his 76' CR900.
Although his bike is fitted with Ronal wheels, the back one has an extremely small hub, and looks as though it may not have a cush drive at all (he can't get it apart as it has that much paint on it!).
In addition, this wheel can't run a speedo drive as the wheel has no provision for a drive plate.
This is his wheel below....
However, I've managed to get hold of a later Ronal for him, exactly like mine, complete but minus the cush drive rubber.
Does anyone know if this one-piece cush drive rubber was made especially for the Ronal, or could it simply be a Kawasaki, H****... or whatever.?
Where can I get one from.?
Here is a pic of the inner side of the later Ronal sprocket carrier that it needs to suit.
Cheers, Will
