Z1 pattern sidepanel fixing
Anyone help .... I have pattern sidepanels on my 1975 Z1 .. these are the type with drilled screw holes ( not lugs ) .... so instead of push fit into rubber dampers I will need to somehow screw into the rubber dampers ... any ideas ???
could try these screwed to to mounting lugs ?
http://www.ebay.co.uk/itm/400473069722? ... 1423.l2649
- Mark Tiller
