Z1 pattern sidepanel fixing
garybrez
#1 PostAuthor: garybrez » Sun Oct 06, 2013 7:41 pm
Anyone help .... I have pattern sidepanels on my 1975 Z1 .. these are the type with drilled screw holes ( not lugs ) .... so instead of push fit into rubber dampers I will need to somehow screw into the rubber dampers ... any ideas ???
Hobbo
yo
#2 PostAuthor: Hobbo » Sun Oct 06, 2013 7:56 pm
Lge washer and nut on the inside of rubber
phil
Z1parR
#3 PostAuthor: Z1parR » Sun Oct 06, 2013 8:25 pm
A root through a bike breakers scrap bin will unearth some knackered bodywork off 16 year old kids scooters .
There are your lugs which once drilled and tapped will push into the frame mounting rubber grommets .
0172 . Geoff Parr
#4 PostAuthor: z1bman » Mon Oct 07, 2013 8:30 am
could try these screwed to to mounting lugs ?
http://www.ebay.co.uk/itm/400473069722? ... 1423.l2649
Mark Tiller
#5 PostAuthor: Mark Tiller » Mon Oct 07, 2013 4:44 pm
The Club replacements are very good
