hi all having problems with mod wired up as per instructions but with kill switch in off i'am getting power and when in run there is no power,
I have electronic ignition boyer bronsden not dyna s.do I have to some thing
to that,only getting 9.46 at coils before.
coil mod
royboy wrote:I have sorted it out now,it was the 5 pin relay for some reason pin 87a was allways live,put 4 pin relay on now all is working as it should.
thanks for the help
5 pin relays are normally "changeover" units they have a common, normally open and normally closed and two connections for the coil
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
