Rotor
Rotor
Guys do I have to use a special tool to remove the rotor and starter clutch assembly? I have managed to lock the rotor and removed the first bolt.
Bike now finished what a joy!
- Chunks
Ive tried all three methods but had the most success with the steering stem top nut and as paul says the chain filter wrench just get as long as possible bar on your socket ..forget wackin it wiv an hammer and if the engine is still connected to the back wheel shove it in gear and lock the brake on
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
if you are going to use a claw type three leg puller you are more than likely to damage the rotor or the starter clutch. using the original thread in the rotor is the only way to remove it. just keep tightening / shock the bolt until it wont tighten any more then give the bolt a good smack with a copper hammer
guys thanks for all your help with this. I didn't remove the rotor in the end but have just purchased a new bolt which came with the woodruff key i think. Little half moon piece of steel.
Do i need this if the rotor was not removed and if so where does it go?
