Marve's BiTsA Z1000j3
garyd
#31 PostAuthor: garyd » Thu Jun 06, 2013 9:21 pm
Admit it....you left it in the garage and the mice got at it :D
At least something is getting done...keep at it.
marve114
#32 PostAuthor: marve114 » Fri Jun 07, 2013 6:15 am
LOL love it Gary quality !
Where's the best place to get an offset sprocket for a gpz1100 a3 motor ?
#33 PostAuthor: Ginger Bear » Fri Jun 07, 2013 5:11 pm
Debben will probably have 'em on the shelf.
# 104
marve114
#34 PostAuthor: marve114 » Tue Jun 11, 2013 9:54 pm
Well put the bike in van and took it for a drive to check my bodge it wheel alignment :)
I was only 5mm out
So got it home and pulled the rear wheel out
Removed spacer that I've got to make 5mm thicker and after some carefull measuring and best efforts with my crayons came up with this
I gave these to a good friend who will make this for me so on e I e got a rear brake sorted I can get the spacer made for the other side then the wheel alignment is done. Only taken 2 years !!!!!
Also orderd a 15mm offset front sprocket today from debbens things are moving along
marve114
#35 PostAuthor: marve114 » Sat Jun 29, 2013 6:12 pm
All done rear brake sourced spacers made
Here is the chain run might have to take a few mm off the sprocket carrier but coming along
marve114
#36 PostAuthor: marve114 » Mon Jul 08, 2013 12:15 pm
So I got my marving exhaust from padders thanks lad !
So I installed it and then one thing led to another and I cleaned the carbs out and run it up
Settings on the mikuni's 36mm
17.5 pilots
126 mains
Mixture screws turned out to 1 3/4 - 2 turns
Not perfect but best I've had em running so here is a video
http://i393.photobucket.com/albums/pp17 ... f448f2.mp4
marve114
#37 PostAuthor: marve114 » Mon Jul 08, 2013 1:15 pm
Couldn't help but post a couple of sunshine pictures :)
MCZ900
#38 PostAuthor: MCZ900 » Mon Jul 08, 2013 1:22 pm
Looking good.
1973 Z1 and 1976 Z900
marve114
#39 PostAuthor: marve114 » Tue Jul 09, 2013 8:23 pm
Having a play around with the rear light
Thinking about junking the original item and moulding in this gpz600 item
For a more slim compact look
Thoughts ?
Please bear in mind this is just rest together at the moment .
Youngest paid up member !
Gus
#40 PostAuthor: Gus » Tue Jul 09, 2013 9:45 pm
Nice build Marve.
That back light looks 10x better than the original already.
Keep up the good work
Gus
"Set the GRINDER on it"
snotie1965
#41 PostAuthor: snotie1965 » Sun Jul 28, 2013 4:57 pm
How is the build going ? looks great so far ....
big green bus
#42 PostAuthor: big green bus » Mon Jul 29, 2013 9:11 pm
Keep the pics coming
:D
marve114
#43 PostAuthor: marve114 » Sun Aug 04, 2013 1:43 pm
Been a week or so not done much to the bike so i got out there today to address chain rubbing problem on the swing arm
This was the problem
As you can see there is a point that touches to arm, So this happened
Then i cut a small slot in the existing material and hammerd it flat to remove the curve turned it up side down and droped into place
Got to get this welded up but i should now have no problems with the chain run :twisted:
garyd
#44 PostAuthor: garyd » Sun Aug 04, 2013 3:20 pm
Ingenious
The Zedster
#45 PostAuthor: The Zedster » Sun Aug 04, 2013 6:37 pm
just found this thread, liking the work so far, that was a neat trick cutting the swing arm
pete
