At least something is getting done...keep at it.
Marve's BiTsA Z1000j3
Well put the bike in van and took it for a drive to check my bodge it wheel alignment
I was only 5mm out
So got it home and pulled the rear wheel out
Removed spacer that I've got to make 5mm thicker and after some carefull measuring and best efforts with my crayons came up with this
I gave these to a good friend who will make this for me so on e I e got a rear brake sorted I can get the spacer made for the other side then the wheel alignment is done. Only taken 2 years !!!!!
Also orderd a 15mm offset front sprocket today from debbens things are moving along
I was only 5mm out
So I got my marving exhaust from padders thanks lad !
So I installed it and then one thing led to another and I cleaned the carbs out and run it up
Settings on the mikuni's 36mm
17.5 pilots
126 mains
Mixture screws turned out to 1 3/4 - 2 turns
Not perfect but best I've had em running so here is a video
http://i393.photobucket.com/albums/pp17 ... f448f2.mp4
17.5 pilots
126 mains
snotie1965
- big green bus
Been a week or so not done much to the bike so i got out there today to address chain rubbing problem on the swing arm
This was the problem
As you can see there is a point that touches to arm, So this happened
Then i cut a small slot in the existing material and hammerd it flat to remove the curve turned it up side down and droped into place
Got to get this welded up but i should now have no problems with the chain run
Youngest paid up member !
- The Zedster
- Regular Poster
