Fork Seal Replacement
I've never replaced the seals on my 77 Z1000 but one of them is now leaking a fair bit.
Anything I need to watch out for, any tips for dismantling the forks, removing the seals etc, best type / weight of fork oil, amount of oil recommended if anything other than standard.
I'm on standard springs at the moment but have progressive springs sitting if anyone can give me any info on whether fitting these makes much of a difference or if they require / benefit from a heavier fork oil or more oil.
I bought two genuine Kawasaki seals from ZPower rather than pattern ones.
Thanks.
John
Thanks.
John
Some 3/8 socket extensions!!!!
I dont know if its such a big issue with the early forks but putting the springs in one way up or the other effects the final oil level in the J forks because more coils lower down make for greater displacement of oil and therefore a higher final oil level. This is WRT springs that are more tightly wound one end more so than the other.
						A few things to keep in mind...
Use a rattle gun to remove the 8mm socket hex headed bolts, ensure you have good copper or fibre seals on these bolts when assembling. I'm pretty sure on the z1000-A1, the dampers don't have the flats to grip them to undo these bolts... hence, the rattle gun!
Sometime a little heat will help to ease the old seals out and prevent damage to alloy top of leg.
I use 15 wt oil and measure fork oil quantity from specifications.
Note.. Half 10 wt + half 20wt = 15 wt. (if 15 wt not available)
RegardZ
RegardZ
Thanks guys.
ADRIAN H, do the progressive springs use the standard spacer or do they remove the need for the spacer? I don't have any instructions for the progressive springs.
zorded, I take it the 3/4 " extensions were used to hold the damper rod steady while you undid the allen bolt? If I take the fork leg off is it possible to replace the seal without fully dismantling the leg?
Has anyone tried this,
http://www.ebay.co.uk/itm/Seal-Mate-Too ... 3a820d28fc
Does anyone think it might be worth a try? I've heard of folk using some clear tape or 35mm film wrapped round the forks just above the seal and then rocking the bike on the suspension to clean the seals, just in case it's debris causing the leak.
I bought the forks from kwakmac on the forum and he said he'd been running them fine previously, so I was thinking of using this before taking the forks apart.
John
John
You have to lever the old seals out then use a piece of tube to chap the new seals in.
Easier to phone me when u are ready and we will strip the forks.
It also means you can completely clean out the fork internals of old sludge and oil.
Run the whole bike up and we can do it one evening after I finish work.
Or just bring the legs
regards
Craig
regards
Craig
member number 0664
Who can catch a Kawasaki?
A police helicopter
A police helicopter
