Correct carb overflow pipe
DaveZ1
#1 PostAuthor: DaveZ1 » Fri Jun 28, 2013 3:49 pm
Does anyone know the OD and the ID of the overflow pipes from the carbs? all four of mine were missing and I want to replace them with the correct size/look (or as near as dammit) as the originals. (73 Z1 BTW)
Cheers, Dave.
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Fri Jun 28, 2013 4:02 pm
Dave
Z-power stock the correct size which is pretty much the same OEM.
Regards
Steve
DaveZ1
#3 PostAuthor: DaveZ1 » Fri Jun 28, 2013 4:21 pm
Cheers Steve, Zpower want 12 quid plus p&p. Just saw correct size fuel / breather pipe for about 2 quid per meter. So if some kind soul could let me know the correct size i may not have to make Mr Marsden any richer.!
Cheers. Dave
Mark Tiller
#4 PostAuthor: Mark Tiller » Fri Jun 28, 2013 4:36 pm
6mm bore and 1mm wall...8mm od
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Fri Jun 28, 2013 4:47 pm
Dave
Take your pick...I've just measured a rock hard set that came off my 73 bike but not saying they are original and they measure 7mm OD and 3mm ID.
Regards
Steve
DaveZ1
#6 PostAuthor: DaveZ1 » Fri Jun 28, 2013 5:48 pm
Thanks chaps, i think the smaller ones are correct.
DogsbolloxofZ1B
#7 PostAuthor: DogsbolloxofZ1B » Mon Jul 01, 2013 7:56 am
Agree with Steve,
I've got NOS ones in the bag and 3mm ID 7mm OD.
Mike
DaveZ1
#8 PostAuthor: DaveZ1 » Mon Jul 01, 2013 12:11 pm
Thanks for taking the trouble to measure your NOS pipes Mike, thats the size I was thinking on being correct.
The best I have found on ebay is this vaccum pipe which is the right size and should be fuel resistant,
http://www.ebay.co.uk/itm/260418204980? ... 1439.l2648
I've ordered 3 metres which should be enough for the four overflows, would be really helpfull to know the length of each as they're all different lengths if you have them off the bike mate. :wink:
I can probably guess somewhere near but it would be nice to know they're right.
Cheers, Dave
wilsonsjw11
#9 PostAuthor: wilsonsjw11 » Mon Jul 01, 2013 12:43 pm
Dave,
Don't forget the retaining clips too :)
Regards
Steve
