1. Whats the best way to remove grips without damaging them? existing grips are A1 nick but wrong type for my Z1B as they are Z1000 type.
2. Whats the best way to fit new grips.
Bar Grips
John,
in reverse order,
2, Dunk 'em in warm water & then just slide 'em on
The water will dry out in no time, don't use oil, grease or spray lube
1, To remove old ones (as long as they ain't glued on), carefully use a flat blade screwdriver & work it in and around until all way down. Whilst doing this a spray of WD40 or Duckoil (other lubrication brands are available
) will ease the operation
in reverse order,
Users browsing this forum: Google [Bot] and 16 guests
