A right old 650 / 750 Mess
Royalratch
Royalratch
Royalratch
oldtimer wrote:Royalratch wrote:Many thanks for your help guys.
Zed105 - is there no way to just use what I have here? It looks like some beefy spacers would do the trick...?
Take a look at the front mounts of the ZR 750 Zephyr, ZR7 and GPX 750.
http://www.ebay.co.uk/itm/KAWASAKI-ZEPH ... _25wt_1018
Are these no use then?
Royalratch
Re: mounts
kev edwards wrote:http://www.ebay.co.uk/itm/83-KAWASAKI-ZX750A-GPZ750-ENGINE-MOTOR-MOUNTS-/280700718113?pt=Motorcycles_Parts_Accessories&hash=item415b110c21
Those will not do it.
There is no std kawasaki configuration that uses your combo of frame and cases.
You will need to make up some one off mounts and spacers.
I would also consider going up on the engine bolts size for those from 10mm to 12mm to aid rigidity and reduce flexing.
Royalratch
