I need to be at Hatfield Services by 9-45 or Mr U will be mad.
Ted
martinz1000r wrote:GPz1100 just failed it's MOT but all easy fix items so I should be fine. I can meet either at the services or closer to Oxford it's self as will be using western by-pass
nick pearce wrote:Good luck with the Zed Jon. Just put a new battery on the ELR and fitted a JMC arm which has brought the ride height up even more with the piggy back Ohlins resulting in better handling and faster steeringWill message you at the end of the week to see how your'e getting on. Cheers Nick.
