MOT Question
ROZZER
#31 PostAuthor: ROZZER » Tue Jan 22, 2013 4:37 pm
My understanding has always been that if indicators are fitted to the bike, then they must work, end of. I don't think that it is compulsory to have them fitted at all, no matter what year of manufacture.
Or am I way off here?
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
#32 PostAuthor: Pigford » Tue Jan 22, 2013 5:19 pm
john_roscoe wrote:My understanding has always been that if indicators are fitted to the bike, then they must work, end of. I don't think that it is compulsory to have them fitted at all, no matter what year of manufacture.
Any lighting "fitted" to a bike must be operational.......
...... as for winkers & the year fitted - not sure if they are compulsory :?: but might be as a front brake switch is after a certain date... I think :??
Wheres Jimmock - I'm Confused :evil:
#33 PostAuthor: zed1015 » Tue Jan 22, 2013 6:28 pm
Pre 86 no indicators needed.
Post 86 manufacturers had to equip new machines with indicators that comply to BS standards.
LOOPHOLE - Any machine predominantly used off road or is a converted race/competition machine and has no passenger provision is exempt .
This is aimed mainly at trials and enduro machines etc that use the highway between sections but if you use (or say you use :wink: ) your road bike for road class sprints, RWYB etc then you are ok.
My Zeph1r which is on a mid 90's plate has no indicators,rear pegs, chainguard, headlight etc is perfectly legal.
Minimum requirements are Brake light and Horn.
#34 PostAuthor: Pigford » Tue Jan 22, 2013 6:31 pm
zed1015 wrote:Minimum requirements are Brake light, Rear reflector and Horn.
Don't need a brake light on eral old shit :wink:
#35 PostAuthor: zed1015 » Tue Jan 22, 2013 6:35 pm
Pigford wrote:
zed1015 wrote:Minimum requirements are Brake light and Horn.
Rhencullen
#36 PostAuthor: Rhencullen » Tue Jan 22, 2013 6:50 pm
zed1015 wrote:My Zeph1r which is on a mid 90's plate has no indicators,rear pegs, chainguard, headlight etc is perfectly legal.
I'm presuming that's for a daytime 'race' MOT.....
Pigford wrote: but might be as a front brake switch is after a certain date... I think :??
Front brake light needed after 1984. Rear only before then.
1984 GPZ900R A1
2002 ZRX1200S
1981 Suzuki GS1000G + 1977 GT750B
#37 PostAuthor: Pigford » Tue Jan 22, 2013 7:08 pm
REAL :oops:
#38 PostAuthor: zed1015 » Tue Jan 22, 2013 7:36 pm
Pigford wrote:
Don't need a brake light on real old shit :wink:
Yeah, Pre 1936 clonkers and pre 1986 under 50cc and under 25mph peds.
Oh! My typo earlier .
Don't need reflector either so just brake light and horn.
#39 PostAuthor: zed1015 » Tue Jan 22, 2013 7:45 pm
Yes! Hours of daylight MOT.
No such thing as a "Daytime" MOT really.
Just a normal mot but you get an advisory certificate stating no lights fitted at time of MOT.
If you want to fit lights later you have to get a fresh MOT though .
#40 PostAuthor: Pigford » Tue Jan 22, 2013 8:07 pm
My pal has a mid 1960's Matchless GL3 in trials trim - no lights whatsoever - no reflector or horn (ignition runs on a magneto only) and has a legit MOT :wink:
#41 PostAuthor: zed1015 » Tue Jan 22, 2013 10:19 pm
Pigford wrote:My pal has a mid 1960's Matchless GL3 in trials trim - no lights whatsoever - no reflector or horn (ignition runs on a magneto only) and has a legit MOT :wink:
Been researching this as the regs seem to contradict themselves due to the convoluted wording so favoured by those who make all this up ( No suprise there :roll: ) but YES! you can run with no lights at all not even a brake light.
Looks like you still need an audible warning device though, pre 73 a bulb horn and after that a device of constant tone i.e battery operated horn.
jimmock
#42 PostAuthor: jimmock » Wed Jan 23, 2013 11:27 am
I'd imagine a speedo too???
Jimmock. :wnkr
I hate people I don't like !
#43 PostAuthor: zed1015 » Wed Jan 23, 2013 11:51 am
jimmock wrote:I'd imagine a speedo too???
Don't need a speedo for the MOT but you do need one to be legal on the highway.
You don't actually need to remove the lights for a "daytime" MOT either just permanently disconnect and paint or mask over them.
#44 PostAuthor: Pigford » Wed Jan 23, 2013 12:06 pm
Rob, I agree that I think a Tooter is required no matter what :!:
jimmock
#45 PostAuthor: jimmock » Wed Jan 23, 2013 8:20 pm
Mental, aint it??
You'd think the MOT would make you legal on the road.
I can remember when I was a Vehicle Examiner with VI (now called VOSA).
I could issue a MOT cert in one hand and a prohibition notice (GV9 / PG9) in the other.
The situation that arose often that warranted this action was a retest for a lorry or bus. Only the items failed can be retested, however if ANOTHER defect was "found" whilst checking the retest items.
If the retest items were good it MUST pass.
But you cannot let it drive away with a dangerous defect, so a prohibition notice would NEED to be issued.
Again MENTAL, but they were the rules.
Jimmock. :wnkr
