The down tube is not bent as I put a straight edge along it.
All of the engine mounting bolts and plates are from the LTD
Any thoughts?
Make a new bracket?
cheers
Nigel
nigel bessant wrote:Z1parR wrote:Z1parR wrote:What hole centres are needed A - B - C
A being top B engine C lower .
I have a plate that is 72mm between these points , is that the one that's needed Nigel
Cheers for that I'll measure it and let you know.
Mark Tiller wrote:I would line up the front first and then see where was out
garyd wrote:Have you tightened up all the other bolts?
if so..loosen them all off so the engine can be jiggled.
They weren't made to very good tolerences in those days and 30 years of a flexi frame...( I know I've held onto the bars like a rag doll on more than one occasion) may well have taken it's toll.
