New Project 2011/2012 /2013/2014!!
- z1000puddin
- z1000puddin
- z1000puddin
Finally braved the cold to fit the front end & rear wheel
I will need to get Mrs puddin to give me a lift down this week end
( I need to invest in a bike lift next time)
I need to double check the tyre clearance, once the full weight is on the wheels & to finalise the wheel & brake caliper mount spacers.
The caliper is leaning in about 2-3mm. So I will have a bit of machining to do this week.
The front mudguard is sitting a little too high, but I have adjustment on the guard brackets.
Zed til Dead
- RALPHARAMA
I have to say - I was wondering how you were going to get it down - Mrs Pudding must be a mighty strong lass
I'd be scared to share a bed with a gurlie who could lift Big Zeds
Looking good. How did you make the tail piece?
Ralph Ferrand
- z1000puddin
Thanks guys,
I asked Mrs puddin this evening to give me a lift,
It was never really going to happen,
So my mate is coming over & I will hook up a chain block & web strop to lift & lower.
Ralph the tail piece was made from a plasma cut piece of 2.5thk aluminium,
I then used the press brake to form the shape.
The tail kick was done the old fashioned way "beaten" into shape over a frost sandbag.
Finally the return at the rear end was welded & dressed.
stu
stu
Zed til Dead
- z1000puddin
Well, Mrs puddin did come out to assist in the heavy lift
(she had the right jacket on James Jack Cranes)
The risk assessment was carried out by all parties & the method statement was read, understood & signed off.
Came down very easily although the garage roof rafter did creak a bit
No immediate issues with tyre clearance or chain clearance, so I dont think I will fit the chain slider at the moment.
Also trial fitted Daves (Exhaust craft) 4-1 underseat down pipes - fitted perfectly with a good half inch clearance from the sump plug.
Dave I will pm you regarding the link pipe to the tail pipes.I dont want to go the flexi pipe option, so this will need a couple of hard sized mandrel bent tubes.
Although I still need to remove the sump again as whilst carrying out the "heatshrink" on the cylinder studs, I got bored with using the wifes hair dryer & tried to speed things up using a desposable lighter
The little metal roller melted off & dropped into the sump, burning my finger in the process!!Bugger bugger.
Zed til Dead
- z1000puddin
Glad you found it!
You wanna ask Santa for one of these......
http://www.toolstation.com/shop/p36371
- z1000puddin
Steve,
The bad thing is I have a heat gun at work ,but forgot to take it home & was too much of a rush to do the job.
Mr Pigford,
I do hope you are meaning my bikes & not Mrs puddins assets
"Quote", Ohhh, what a lurverly pair
By the way I am the one behind the camera
Just ordered my brake lines from Uptheshophttp://stores.ebay.co.uk/uptheshop
Venhill black carbon with black banjo/ banjo bolts ( I have a think for black
Mr Pigford,
Zed til Dead
Users browsing this forum: No registered users and 5 guests
