New Project 2011/2012 /2013/2014!!
z1000puddin
#16 PostAuthor: z1000puddin » Thu Nov 15, 2012 10:34 pm
Neil,
Have a look at the pics further back on the thread.
The fork extensions slip over the tops of the USD forks Similar to these.
http://www.google.co.uk/imgres?q=fork+e ... ,s:0,i:268
Zed til Dead
#17 PostAuthor: Pigford » Fri Nov 16, 2012 7:47 am
Yep, those are mine - for me Z1000 :!:
z1000puddin
#18 PostAuthor: z1000puddin » Sun Nov 25, 2012 8:07 pm
Cylinder Head all done.
Trial fitted the 28mm carbs.
Forks due back from Mikey on Tues/Wed - So hopefully get it on the wheels next week.
Then send the painting bits to Si. @ Flying Tiger
While that is going on I will get the wiring all done
Looking like Feb to get it all done.
Zed til Dead
mikey
#19 PostAuthor: mikey » Sun Nov 25, 2012 9:12 pm
That really is taking shape stu keep at it mate
z1000puddin
#20 PostAuthor: z1000puddin » Mon Dec 03, 2012 9:49 pm
Finally braved the cold to fit the front end & rear wheel
I will need to get Mrs puddin to give me a lift down this week end
:shock: ( I need to invest in a bike lift next time)
I need to double check the tyre clearance, once the full weight is on the wheels & to finalise the wheel & brake caliper mount spacers.
The caliper is leaning in about 2-3mm. So I will have a bit of machining to do this week.
The front mudguard is sitting a little too high, but I have adjustment on the guard brackets.
Zed til Dead
#21 PostAuthor: Pigford » Tue Dec 04, 2012 7:34 am
Yep - thats looking real sweet :twisted:
RALPHARAMA
#22 PostAuthor: RALPHARAMA » Tue Dec 04, 2012 9:02 am
I have to say - I was wondering how you were going to get it down - Mrs Pudding must be a mighty strong lass :lol: I'd be scared to share a bed with a gurlie who could lift Big Zeds :lol:
Looking good. How did you make the tail piece?
Ralph Ferrand
z1000puddin
#23 PostAuthor: z1000puddin » Tue Dec 04, 2012 8:52 pm
Thanks guys,
I asked Mrs puddin this evening to give me a lift, :?? :??
It was never really going to happen, :D :D
So my mate is coming over & I will hook up a chain block & web strop to lift & lower.
Ralph the tail piece was made from a plasma cut piece of 2.5thk aluminium,
I then used the press brake to form the shape.
The tail kick was done the old fashioned way "beaten" into shape over a frost sandbag.
Finally the return at the rear end was welded & dressed.
stu
Zed til Dead
Crofty
#24 PostAuthor: Crofty » Tue Dec 04, 2012 9:14 pm
Smart looking project :D
z1000puddin
#25 PostAuthor: z1000puddin » Tue Dec 04, 2012 10:18 pm
Well, Mrs puddin did come out to assist in the heavy lift :D
(she had the right jacket on James Jack Cranes)
The risk assessment was carried out by all parties & the method statement was read, understood & signed off. :lol: :lol:
Came down very easily although the garage roof rafter did creak a bit
:shock:
No immediate issues with tyre clearance or chain clearance, so I dont think I will fit the chain slider at the moment.
Also trial fitted Daves (Exhaust craft) 4-1 underseat down pipes - fitted perfectly with a good half inch clearance from the sump plug.
Dave I will pm you regarding the link pipe to the tail pipes.I dont want to go the flexi pipe option, so this will need a couple of hard sized mandrel bent tubes.
Although I still need to remove the sump again as whilst carrying out the "heatshrink" on the cylinder studs, I got bored with using the wifes hair dryer & tried to speed things up using a desposable lighter :oops: :oops:
The little metal roller melted off & dropped into the sump, burning my finger in the process!!Bugger bugger.
Zed til Dead
#26 PostAuthor: Pigford » Wed Dec 05, 2012 7:38 am
Ohhh, what a lurverly pair :!:
z1000puddin
#27 PostAuthor: z1000puddin » Wed Dec 05, 2012 9:46 pm
GOT THE SUMP BACK OFF TO LOCATE THIS LITTLE BUGGER
The moral is NEVER use a cheap lighter to shrink heat shrink without blocking up the crankcases properly
:oops: :oops: :??
Zed til Dead
#28 PostAuthor: Ginger Bear » Thu Dec 06, 2012 8:02 am
Glad you found it!
You wanna ask Santa for one of these......
http://www.toolstation.com/shop/p36371
# 104
z1000puddin
#29 PostAuthor: z1000puddin » Thu Dec 06, 2012 5:36 pm
Steve,
The bad thing is I have a heat gun at work ,but forgot to take it home & was too much of a rush to do the job. :oops: :oops:
Mr Pigford,
I do hope you are meaning my bikes & not Mrs puddins assets :lol:
"Quote", Ohhh, what a lurverly pair :!:
By the way I am the one behind the camera :wink:
Just ordered my brake lines from Uptheshophttp://stores.ebay.co.uk/uptheshop
Venhill black carbon with black banjo/ banjo bolts ( I have a think for black :wink:)
Zed til Dead
750steve
#30 PostAuthor: 750steve » Thu Dec 06, 2012 6:39 pm
Users browsing this forum: Bing [Bot] and 10 guests
