engine
jonhunt
engine
#1 PostAuthor: jonhunt » Sun Nov 04, 2012 7:27 pm
Considering this has been kicking around my garage floor for 14 years it surprisingly good
#2 PostAuthor: kev edwards » Sun Nov 04, 2012 7:33 pm
You might need A new spark plug there Jon. :)
jonhunt
#3 PostAuthor: jonhunt » Sun Nov 04, 2012 7:44 pm
& lots of other bits :D
#4 PostAuthor: Pigford » Sun Nov 04, 2012 8:03 pm
That does look good Jon :wink:
KeithZ1R
#5 PostAuthor: KeithZ1R » Sun Nov 04, 2012 8:12 pm
WOW. a workmate as old as mine :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
PJ
#6 PostAuthor: PJ » Sun Nov 04, 2012 9:02 pm
What's the plan John - put it in a fizzy???
jonhunt
#7 PostAuthor: jonhunt » Sun Nov 04, 2012 9:05 pm
My uncle was a joiner & I got into woodwork as a kid. I thinks its one of the first cast aluminium ones with four pipes
Z1parR
#8 PostAuthor: Z1parR » Sun Nov 04, 2012 9:10 pm
Jon what's the splendid looking machine with the red mudguard :D
0172 . Geoff Parr
jonhunt
#9 PostAuthor: jonhunt » Sun Nov 04, 2012 9:26 pm
H**** S65 Pressed steel frame probably won't take 82 bhp
jonhunt
#10 PostAuthor: jonhunt » Sun Feb 17, 2013 6:06 pm
Pulled some more bits off. Cams, valve buckets bearings. Can't get the head to shift, Apart from brute force any recommendations.
#11 PostAuthor: zed1015 » Sun Feb 17, 2013 10:22 pm
A whack with a rubber mallet front and back on the smooth protrusions of the camchain tunnel never fails.
You haven't forgot the two 10mm bolts near the outer spark plugs though have you ?
ollie
#12 PostAuthor: ollie » Sun Feb 17, 2013 10:36 pm
You were quicker than myself Rob :wink: about the two bolts either end ,easily overlooked by many hence busted fins on cylinder heads !!! :roll:
jonhunt
#13 PostAuthor: jonhunt » Mon Feb 18, 2013 10:34 am
Got those ones
ollie
#14 PostAuthor: ollie » Mon Feb 18, 2013 12:55 pm
good man :wink: ,just do as Rob says and it should free itself :wink:
