Converting a Spectre/ST to chain
Mr Puffin
#1 PostAuthor: Mr Puffin » Sun Oct 07, 2012 4:48 pm
Just wondering how much work would be involved or if indeed it would be worth it cost wise :?:
Any input appreciated :D
steve.w
#2 PostAuthor: steve.w » Sun Oct 07, 2012 5:45 pm
i have heard u just remove the shaft mechanism and use a z1000 inner sprocket cover ..and then fit a sprocket onto the shaft but not sure.. but theres a shaft engine in my garage wots gonna have the same treatment :wink:
#3 PostAuthor: z1bman » Sun Oct 07, 2012 6:02 pm
you would have to replace the output shaft with one from a z1000j or gpz1100 as they are different
steve.w
#4 PostAuthor: steve.w » Sun Oct 07, 2012 6:09 pm
z1bman wrote:you would have to replace the output shaft with one from a z1000j or gpz1100 as they are different
nice to know :wink:
#5 PostAuthor: zed1015 » Sun Oct 07, 2012 6:11 pm
For the J style non kickstart engine .
You need -
Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
gpz/j gear selector shaft.
gpz/J inner cover/seal holder.
gpz/J sprocket cover.
sockpuppet
#6 PostAuthor: sockpuppet » Sun Oct 07, 2012 7:14 pm
Is this a Unitrak Gpz shaft ?
Its just that i have two GPZ1100b2 `s and both have the bolt type ,
and world`s most complex retaining washer system !!!!
Regards
Mick
#7 PostAuthor: zed1015 » Sun Oct 07, 2012 8:33 pm
sockpuppet wrote:Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
Regards
Mick
Ah. yes! a unitrac one.
Mr Puffin
#8 PostAuthor: Mr Puffin » Sun Oct 07, 2012 10:06 pm
Thanks guys
zed1015 wrote:For the J style non kickstart engine .
You need -
Thanks for the comprehensive reply Zed :beer Looks like this will be a viable project :)
jimmock
#9 PostAuthor: jimmock » Sun Oct 07, 2012 11:27 pm
I think our very own Iain Marshall has done this before???
Jimmock. :wnkr
I hate people I don't like !
nanno
#10 PostAuthor: nanno » Mon Oct 08, 2012 5:10 am
Regards
Mick
But beware, you can't use the input-shaft, as it's longer. Just did this with my Z1000J, because I got hold of a set of Z1100ST cases and you just swap all the bits from the J to the ST and voila you have a beautiful engine.
Greg
Mr Puffin
#11 PostAuthor: Mr Puffin » Mon Oct 08, 2012 12:36 pm
Plenty of good info coming through here and its appreciated :D
