Z1000 st headstock bearings
nigel bessant
#1 PostAuthor: nigel bessant » Sat Sep 29, 2012 5:53 pm
Evening all, can anyone tell me the headstock bearing numbers, both inner and outer for a shaft drive thou?
Nigel
#2 PostAuthor: ADRIAN H » Sat Sep 29, 2012 7:58 pm
z-power list them. part numbers on the pictures 92116-1008, 92116-1009
https://www.z-power.co.uk/merchantmanag ... ts_id=2036
nigel bessant
#3 PostAuthor: nigel bessant » Sat Sep 29, 2012 8:38 pm
Cheers Adrian
#4 PostAuthor: Ginger Bear » Sun Sep 30, 2012 7:29 am
Nigel, Yesterday I fitted a set of 'All Balls' taper berarings that came from Jeff at Z1 Enterprises. Excellent price + they come with dust seal's. :D
http://www.z1enterprises.com/ItemDetail ... =AB22-1009
# 104
nigel bessant
#5 PostAuthor: nigel bessant » Sun Sep 30, 2012 12:26 pm
GB, thanks for info, I have discovered that the headstock on the st is different from the standard z1000. The outer bearing diameter is somewhat larger. I am going to have to attempt to source a suitable pair. Probably have to buy a st bottom yoke and start again with the yoke conversion.
:roll:
hillbilly
#6 PostAuthor: hillbilly » Sun Sep 30, 2012 12:56 pm
if you know the measurements,try these guys.
http://simplybearings.co.uk/shop/Taper+ ... index.html
#7 PostAuthor: Ginger Bear » Sun Sep 30, 2012 4:32 pm
Nigel, I'd agree with Hillbilly, you should find what you need at Simply Bearings. :up
# 104
nigel bessant
#8 PostAuthor: nigel bessant » Sun Sep 30, 2012 7:00 pm
Ginger Bear wrote:Nigel, I'd agree with Hillbilly, you should find what you need at Simply Bearings. :up
Yes, I'll them a go. I think I'll give z1 enterprises an email too.
Cheers Brent for the info.
Probably have a set of secondhand bearings going cheap if I can get them out of the headstock without damaging the outer race :(
Thanks again for info
Nigel
hillbilly
#9 PostAuthor: hillbilly » Mon Oct 01, 2012 4:09 pm
no probs mate. :wink:
