Evening all, can anyone tell me the headstock bearing numbers, both inner and outer for a shaft drive thou?
Nigel
Z1000 st headstock bearings
nigel bessant
z-power list them. part numbers on the pictures 92116-1008, 92116-1009
https://www.z-power.co.uk/merchantmanag ... ts_id=2036
nigel bessant
Nigel, Yesterday I fitted a set of 'All Balls' taper berarings that came from Jeff at Z1 Enterprises. Excellent price + they come with dust seal's.
http://www.z1enterprises.com/ItemDetail ... =AB22-1009
nigel bessant
if you know the measurements,try these guys.
http://simplybearings.co.uk/shop/Taper+ ... index.html
nigel bessant
Ginger Bear wrote:Nigel, I'd agree with Hillbilly, you should find what you need at Simply Bearings.
Yes, I'll them a go. I think I'll give z1 enterprises an email too.
Cheers Brent for the info.
Probably have a set of secondhand bearings going cheap if I can get them out of the headstock without damaging the outer race
Thanks again for info
Nigel
