what light is fitted?
captaincaveman
#1 PostAuthor: captaincaveman » Sat Sep 15, 2012 12:06 pm
just wondered if this is off another gpz, quite fancy getting something almost standard looking but without it sticking out from the body work like the original
Jay
81 GPz1100 B1
tlc
International Rep
#2 PostAuthor: tlc » Sat Sep 15, 2012 1:47 pm
That's a common mod where the bracket is simply shortened.
Ginger Bear has done it recently.
Asphalt Cowboy
needaz1100r
#3 PostAuthor: needaz1100r » Sat Sep 15, 2012 5:38 pm
I have one already done, badly, i have to say, (not by me) and with indicator mounts needing repair, but you can have it for a fiver plus postage
captaincaveman
#4 PostAuthor: captaincaveman » Sun Sep 16, 2012 10:04 am
needaz1100r wrote:I have one already done, badly, i have to say, (not by me) and with indicator mounts needing repair, but you can have it for a fiver plus postage
ive got an original one here, never realised they could be modded, i havent got a paypal account at the moment?
Jay
81 GPz1100 B1
#5 PostAuthor: Ginger Bear » Sun Sep 16, 2012 2:28 pm
The rear mudguard I had fitted was a 'period' accessory made in glass fibre, that moves the tail light forward, probably 'all the rage' 30 years ago. :roll:
If you still have an uncut original rear mudguard, DON'T cut it. They are worth a small fortune these days, one sold recently on ebay for £150+ :shock:
# 104
captaincaveman
#6 PostAuthor: captaincaveman » Sun Sep 16, 2012 3:45 pm
no havent got the original mudguard, i meant bracket :lol:
so this bracket is shortened? the part with 4 bolts to the subframe?
thats mud not rust by the way :lol:
Jay
81 GPz1100 B1
captaincaveman
#7 PostAuthor: captaincaveman » Mon Dec 31, 2012 6:00 pm
bumping this back up, any ideas on how i cut the bracket?
Jay
81 GPz1100 B1
steve.w
#8 PostAuthor: steve.w » Mon Dec 31, 2012 6:42 pm
make a bracket ..just a flat one and fasten in to the two threads on the end of frame tubes ..big green bus ..is the man to talk too as he had some made :wink:
captaincaveman
#9 PostAuthor: captaincaveman » Mon Dec 31, 2012 6:46 pm
steve.w wrote:make a bracket ..just a flat one and fasten in to the two threads on the end of frame tubes ..big green bus ..is the man to talk too as he had some made :wink:
thats an idea, i didnt want to cut this one down if i could help it, so pretty much a u-shape out of ally then? :D
Jay
81 GPz1100 B1
tlc
International Rep
#10 PostAuthor: tlc » Mon Dec 31, 2012 9:19 pm
If you just take that bracket off you will see 2 x M8 threads in the rear of the seat rails. Just get a bit of flat on there and mount your lamp.
It's almost as if that's what Kawasaki wanted you to do in the first place.
Asphalt Cowboy
steve.w
#11 PostAuthor: steve.w » Mon Dec 31, 2012 9:46 pm
tlc wrote:If you just take that bracket off you will see 2 x M8 threads in the rear of the seat rails. Just get a bit of flat on there and mount your lamp.
mmmm isnt that just wot i said lol :wink:
tlc
International Rep
#12 PostAuthor: tlc » Mon Dec 31, 2012 10:21 pm
Oh, Steve you wag.
See above and the U shaped bracket. Tis easier as we know.
Asphalt Cowboy
captaincaveman
#13 PostAuthor: captaincaveman » Mon Dec 31, 2012 11:15 pm
so literally on the end of the round tubing then? ah ok i thought you'd have to bolt onto where the existing 4 bolts/bracket are? that sounds easy
now a silly question, what happens with the rear bodywork? mines held in place by a bracket with a slotted square rubber mount? :D
Jay
81 GPz1100 B1
steve.w
#14 PostAuthor: steve.w » Tue Jan 01, 2013 9:34 am
u make a little bit ta put the rubber in :wink:
captaincaveman
#15 PostAuthor: captaincaveman » Tue Jan 01, 2013 11:19 am
ah ok thanks, im sure itll become clear when i start :D
Jay
81 GPz1100 B1
