Harris Magnum 1
#136 PostAuthor: Pigford » Fri Jun 29, 2012 7:04 pm
Been a while :oops: but finally got me arse in gear and finished the front caliper mounts ....... not up to the skills shown by most of you lot, but I made it meself with a pillar drill, hacksaw & half round file.
Got a bit of 1/2" ally plate off eBay - Engineer grade suitable for the job & made a card template.....
Cut the plate up roughly & started work with the hacksaw & file :!:
..... then after a week of spending lunchtimes in the company workshop finished them......
I tapped the plate out for M10 x 1.25 bolts for the lower & middle fittings..... the middle one just needs a 9mm spacer each side... and the top hole is plain 10mm for a nut & bolt arrangement - luckily you can't really see them once fitted - but might have to trim them around flush with the calipers at a later date :P
#137 PostAuthor: paul doran » Sat Jun 30, 2012 10:30 am
they look good Mark well done
sanderz
#138 PostAuthor: sanderz » Sat Jun 30, 2012 6:16 pm
Look the 'biz' them Mr Pigford :up
Pigford wrote: made it meself with a pillar drill, hacksaw & half round file.
Good on ya! Proper fettlin' :wink:
Wots up DOHC
Crofty
#139 PostAuthor: Crofty » Sat Jun 30, 2012 7:24 pm
Nice work piggy
Royalratch
#140 PostAuthor: Royalratch » Sat Jun 30, 2012 9:31 pm
This is gonna be sick.
#141 PostAuthor: Pigford » Tue Sep 04, 2012 3:56 pm
Been a while (again) :|
So......... as the front end is now 99% complete, t'was time I fitted it :!:
Also rigged up the rear end......
Now got a bit of a struggle with sorting out the rear shock.......
need to make a plate up to fix it to the swingarm - and I'm gonna design it to be adjustable ride height.
#142 PostAuthor: Pigford » Wed Sep 05, 2012 4:16 pm
Little bit more tinkering - added some incredibly light Harris clip-on's & started to suss out the rear shock fixing.
ANYONE KNOW WHAT MAKE THE SHOCK IS ?
Never have too many photo's :shock:
Thinking of mounting an alloy bracket on the top of the s/arm brace & using some M16 x 1.5 s/s studding & a bracket to connect to the shock - so it'll be height adjustable :!:
garyd
#143 PostAuthor: garyd » Wed Sep 05, 2012 7:23 pm
A quick guess for the shock is a Hagon.
Flying Tiger
Ted's Biatch
#144 PostAuthor: Flying Tiger » Thu Sep 06, 2012 8:16 am
Looking good Mark! I love the Dymags!
#145 PostAuthor: ADRIAN H » Thu Sep 06, 2012 9:19 am
Keep up the good work, Mark. Good start matey.
Oh and when you get bored with it, I`ll take it off your hands. :lol: :lol: :lol:
#146 PostAuthor: Pigford » Fri Oct 19, 2012 5:45 pm
Finally completed plumbing in the front brakes :!:
I got hold of a new Brembo m/cylinder a while back - think it was destined to a Ducati S/motard 1200 or summink like that :?: All the fittings are Goodridge s/s along with the usual braided hose, etc.
I'm quite pleased with how that worked out.... next was to fit the electrical tray. This is a Harris item made of fibreglass which I then covered with a sheet of hi-tech heat-resistant alloy.
Although there ain't much room, I should be able to squeeze the Dyna coils, reg/rec and fuse box in there :wink:
ash
#147 PostAuthor: ash » Fri Oct 19, 2012 6:21 pm
Anything is possible if you think with your head and not your bollocks, :D
#148 PostAuthor: Pigford » Fri Oct 19, 2012 6:36 pm
ash wrote:Anything is possible if you think with your head and not your bollocks, :D
....... I'll take your experienced word for that, Ash old fella :lol:
ash
#149 PostAuthor: ash » Fri Oct 19, 2012 6:53 pm
Anytime mate :D
coldsummer
#150 PostAuthor: coldsummer » Fri Oct 19, 2012 7:36 pm
That's going to look fabulous Mark.
What colour do you plan to do the frame and wheels in?
