front sprocket washer
hanskloss
#1 PostAuthor: hanskloss » Thu Jun 21, 2012 10:13 pm
Hi all, I've just fitted a brand new sprocket washer bought from Z1 Enterprises and it got chewed up right away while tightening the nut. Could anyone advise if there is better holding type of washer (as pictured below) that fits Z1 shaft please?
mine today :(
#2 PostAuthor: z1bman » Thu Jun 21, 2012 10:27 pm
you need to lubricate the surface of the washer with some grease + make sure you are not over tightening the nut
Garn 1
#3 PostAuthor: Garn 1 » Fri Jun 22, 2012 3:08 am
Agree with Z1bman, however, I find anti-scuffing paste the best, just applied under the nut contact surface. The paste or grease allows the nut to slip past the lock-washer without grabbing it and tearing the lock-tang in the small hole.
hanskloss
#4 PostAuthor: hanskloss » Fri Jun 22, 2012 7:00 am
thanks for the tip z1bman and Garn, quite obvious solution but I didn't think about this... :fou I'll try with moly grease today
Mark Tiller
#5 PostAuthor: Mark Tiller » Fri Jun 22, 2012 9:13 am
Z Power do a self locking nut
buzzard
washers , crap
#6 PostAuthor: buzzard » Fri Jun 22, 2012 3:01 pm
Leave the washer in place, but use Loctite 243 on the threads when assembling, good stuff and it won't come undone. Buzzard
Every man should have a shed (for bikes obviously..)
Garn 1
#7 PostAuthor: Garn 1 » Mon Jun 25, 2012 11:10 pm
A thing I've noticed when using the nyloc larger nut that Mark T suggests, that sometimes, the nylon part of the nut, barely makes the important part of the spindle end, when using a sprocket with the washer for the o-ring chain.
z1000puddin
#8 PostAuthor: z1000puddin » Tue Jun 26, 2012 8:35 pm
We use these washers on numerous offshore applications
http://www.nord-lock.com/default.asp?url=2.16.37
Very Very good, but a tad expensive.
They can be preloaded & are reuseable
stu
Zed til Dead
hanskloss
#9 PostAuthor: hanskloss » Tue Jun 26, 2012 9:01 pm
thanks Gents, I've applied molylube on the nut/washer and loctite on the thread, all sorted now
Users browsing this forum: Google [Bot] and 18 guests
