a raging thirst for oil?
my 1075 j2 has only done 3000 miles since rebuild,it has an oil cooler,gas flowed head,goes like crazy,and only smokes at over 100 miles an hour,a round trip of 200 miles it took a litre of oil,also there are no leaks? also should the camchain rattle,the chap i bought it from reckons this is normal and to tighten any more could do the engine in?
- london calling
- london calling
Jon, at that rate of oil loss, it must be visible somewhere?
Does she smoke on the overrun after a blast
So she don't smoke on start up, ................ or when warm when blipping throttle
No oil puddles after a run
It would be a good idea to get someone to follow you on a run to check for visual smoke from exhaust
- rickman CRR
