Wiring
jovin04
Wiring
#1 PostAuthor: jovin04 » Tue May 15, 2012 3:09 pm
Can anyone help with information regarding the wiring of the Electronic speedo please.
Cheers Vince
Taffus
#2 PostAuthor: Taffus » Tue May 15, 2012 4:30 pm
do you mean the standard electronic speedo from a J or GPz B1?
(\__/)
(")_(")Image
#3 PostAuthor: Al » Tue May 15, 2012 5:02 pm
Measure battery voltage between (white +) and (black/yellow -).
Third wire obviously pulse output to odometer.
Note; it does say to disconnect the three way connector first so i cant see how that would work.
I tested mine and cant remember how i did it but suspect by leaving it connected and pushing the probes into the block.
No you cant take the sensor apart.
All this and all the testing procedure is set out in about five pages in the Kawasaki manual
