clutch help
DavidZ1R
clutch help
#1 PostAuthor: DavidZ1R » Sat Mar 03, 2012 5:22 pm
On my little project z250, i have transfered the engine guts into a new crank cases without dismantling the clutch, I did however pull out the clutch push rod to put in new oil seals, when I have come to put back the housing cover with new cable from z power, with a diff part number?, there is a huge amount of slack even with all play taken up, it does not bite the clutch at all. any help please. :roll: could the little ball bearing in the clutch have moved out or dropped in some way?
jimmock
#2 PostAuthor: jimmock » Sat Mar 03, 2012 6:36 pm
I didn't think the Z250 had a clutch.
I thought they were twist and go??
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
KeithZ1R
#3 PostAuthor: KeithZ1R » Sat Mar 03, 2012 6:46 pm
Summats fell out time to take it to bits im afraid :(
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Robw
#4 PostAuthor: Robw » Sat Mar 03, 2012 8:28 pm
Have you still got the old cable to refit/ measure against the new one as I would ensure that side of things before delving into the clutch.
Rob
DavidZ1R
#5 PostAuthor: DavidZ1R » Sun Mar 04, 2012 1:22 pm
checked the cable for length, seems ok, took off the clutch plate, ball bearing in place, it seems that no pressure is on the clutch release to stop it just turning on the bearings, at a loss :evil: has it on and off dozens of times !!!! HELP!
#6 PostAuthor: z1bman » Sun Mar 04, 2012 1:38 pm
if you remove the sprocket cover what angle is the lever on the clutch lifter pointing to ? does the adjuster screw have to turn anti clockwise to adjust the clutch?
DavidZ1R
#7 PostAuthor: DavidZ1R » Sun Mar 04, 2012 4:25 pm
z1bman wrote:if you remove the sprocket cover what angle is the lever on the clutch lifter pointing to ? does the adjuster screw have to turn anti clockwise to adjust the clutch?
as you look at the cover from the outside ie as looking straight thru, the clutch release is at 25 past as a clock, yes anti clock wise on the screw, as it starts to bite ping it pops off the little lug inside, all sits nice but no tension ? i am baffled!
#8 PostAuthor: z1bman » Sun Mar 04, 2012 6:05 pm
make sure the adjuster in the middle of the cable is fully wound in. adjust the handlebar clutch adjuster so that it is out about 10mm then adjust the clutch from the screw adjuster in the sprocket cover. remember to turn this screw back a quarter of a turn once it is starting to lock . finally put the required amount of free play by adjusting the cable
DavidZ1R
#9 PostAuthor: DavidZ1R » Mon Mar 05, 2012 8:27 pm
Robw wrote:Have you still got the old cable to refit/ measure against the new one as I would ensure that side of things before delving into the clutch.
Rob
Still got no where, so I double checked the cable and feck me its 1" longer on the slack :evil: put the old splitting one back on followed z1bmans advise, perfect, its for a z400 :evil: sorry guys my mistake follow the rule measure twice cut once, live and learn :roll:
