If you're that embarrassed you can pm me. ....... I ain't bringing your wheels back 'tip you 'spill the beans'
Errrrrrrm - Think I may have a serious problem!!!!
OK - some of you are gonna think it wasn't such a bargain, but to justify, its hard to find relatively "un touched" bikes, and although its an LTD, its basically a standard Z1000A2 with different clothes on.
Came with MOT until Aug - no Tax, v. good tyres, c&sprox, fork stanchions, wiring looks untouched, frame paint pretty good, wheel unmarked, 22.5k miles......
The good thing is the frames are more or less the same (I'm 99.9% sure) unlike the later LTD (K1/K2 - CSR) which has been raked
This particular bike runs very strong & sounds v. quiet (mechanically) and still has the tool tray and original handbook!!! (no tools)
Not sure about the pipe - it has a cosha V&H plate on it and the end isn't a typical alloy KERKER insert
The discs show practically zero wear and the rest just ties in nicely.
Anyhow, after all that vindication - £1500
OK Mikey - comment accepted
Anyhow, took her out for a spin, just as the snow started........ Bit awkward to start - most likely due to the K&N's, but once running she goes reall well, pulls cleanly and really takes off
I didn't give her a clean but I did remove the mirrors and grab rail (its a square shaped one) then swapped the shox, bars and seat ......
BEFORE:
AFTER:
Whaddya think
I was considering swapping the paint set for my old black/gold Z1000A2, but this one is growing on me..... so it'll stay for now
Heres a couple of shots of the "Vance & Hines/ Kerker" exhaust.....
Easy oil change access and sounds real nice
Front disc's like with new pads - like new.....
Ohhhh Happy Daze.................
BEFORE:
AFTER:
Whaddya think
- paul doran
- coldsummer
Padders wrote:I agree with Simon I would have just kept it as it was and ride it.
Looks like it will be a tight squeeze in the garage Mark if you need me to take theTriumph off your hands just drop me a pm
The Trumpet is a favourite of mine - but everything has a price
Went out for a spin on the bike today - did about 10 miles, after I spent 5 mins trying to start it from cold
Rides luverly - idles great - has a bit of a "hunting" flat spot on slight throttle when cruising along - also spits a bit from closed to part throttle.
After the ride I found the main earth lead from the battery was dodgy - it was connected with corroded wires to the frame engine mount above the r/h footrest, so re-connected it to the r/h rear engine earth point after drilling out the broken bolt & re-tapping - have to see how she starts next time.
