Z800 Cafe Chopper Fighter thing...
Royalratch
Aah - you mean on the gear shaft end of the rod that will then accept a clamp!
Gotcha.
Gotcha.
Royalratch
Yes! you are correct if the threaded portion is part of the link rod.
Is the link rod steel then ? as it looks like aluminium in the pic.
If it's ally i wouldn't trust the 6mm threaded portion to be strong enough.
On closer inspection of your pic though it appears to be a shouldered steel insert pressed or screwed in to the rod ?
Should be removable with little trouble if need be.
Royalratch
Plenty on ebay, left or right hand thread.
I've bought quite a few from this seller.
Right hand
http://www.ebay.co.uk/itm/6mm-FEMALE-ro ... 3f122a4462
Left hand
http://www.ebay.co.uk/itm/6mm-FEMALE-ro ... 4160a23e16
P.S. Just been in the workshop and noticed that the alloy clamp from an 05 ZX10R has a rose joint attached with female threads as you require,
It has to be from an 05 model though as it appeares they switched to a male thread after that.
Right hand
Left hand
Royalratch
Royalratch
Royalratch
Bit of progress made but the right kind as I now have a full on rolling bike with all the trimmings.
Disk spacers have been done so can bolt on the discs.
Headlight brackets done, intreated into the clips on - will be anodised black so they are even more incognito.
The steering lock is also on, basically it;s two screws mounted onto the bottom yoke and depending on how long
they are you can tweak the steering lock.
Gear lever linkage sorted.
And the I had the rear calliper hanger machined from scratch. I'm not sure about this as I specified a design that was
simpler and less bulky and this looks kind of okay but way chunky. Maybe it will look better in black.
Now I basically plumb it up, throw motor in and wire it up and it's ready to go. I won't do a full build and fire up,
I'll do a full dry build and no wiring to check it's all good and everything I need is done - then disassemble and
get everything off for coating / painting.
Royalratch
Users browsing this forum: Bing [Bot] and 17 guests
