Z1-R bars
stale
Z1-R bars
#1 PostAuthor: stale » Sun May 20, 2007 9:59 pm
Can someone tell me the width of the stock Z1-R D1 handle bars ? I mounted the fairing the other day and the mirror mounts ended up on the inside of the fairing... :? There's obviously something wrong. The bars measures 66cm from end to end. cheers
72 H2,99 W650,72 H1C,76 KH250,75 F11,70 G4TR,78 KV75,76 KV80R,71 MT1
SP10mk11
#2 PostAuthor: SP10mk11 » Mon May 21, 2007 6:03 pm
Hi I will measure mine tomorrow and get back to you
Gary
Padders
#3 PostAuthor: Padders » Mon May 21, 2007 8:25 pm
My standard bars are 28 1/2 inch's end to end or 72 1/2 cm if you are metric.
padders
stale
#4 PostAuthor: stale » Mon May 21, 2007 8:48 pm
Thanks guys. 72.5, eh ? I believe those 6.5cm's is just what I need to get the mirrors on the outside of the fairing. Thanks again. Cheers
stale
#5 PostAuthor: stale » Mon May 21, 2007 8:55 pm
Here it is without the fairing. Stock bars with cut ends ? Not stock at all ? Any comments ?
Image[/img]
Padders
#6 PostAuthor: Padders » Tue May 22, 2007 5:52 am
Not stock sorry. The stock ones have a raised section in between the handle bar clamps where the wiring pulls through. I can send a picture if you want.
padders
Ed Z1-R
#7 PostAuthor: Ed Z1-R » Tue May 22, 2007 8:16 am
Measuring, following top contours its about 84 cm.
stale
#8 PostAuthor: stale » Tue May 22, 2007 4:27 pm
I measured in a straight line between the end of the grips.
Padders, yes a picture would be nice. Thank you. Cheers
Padders
#9 PostAuthor: Padders » Tue May 22, 2007 5:32 pm
The 72.5 is straight between the ends of the grips. Here are a couple of pictures hope they help.
stale
#10 PostAuthor: stale » Tue May 22, 2007 5:45 pm
Thanks, Padders ! Now, does anyone have some stock bars to spare ? Or does anyone know of a good replacement ? Right height and width. Cheers
