Z650 Resurrection.
Exhaust Craft
Exhaust
#91 PostAuthor: Exhaust Craft » Mon Sep 26, 2011 5:08 pm
This is the exhaust that will be going on to finish it off
mikey
#92 PostAuthor: mikey » Mon Sep 26, 2011 6:59 pm
Sweet looking exhaust finish it nicely
GUYZED
#93 PostAuthor: GUYZED » Mon Sep 26, 2011 7:12 pm
pertonpc wrote:Cheers Ian
It was your post of a few weeks ago that got me thinking about these again - they were missing when I got the 650 and I tried the usual places with no joy. They don't even seem to survive onto breakers yard bikes very often.
These are the same ones as for Z1000 I believe. So scarce I am debating whether to even fit them cos they aren't really that functional are they??
Guy,
They are called limiter caps and they fit over the air screw on the underside of 650/1000 carbs from the factory. I think the idea was to set the air screws so the mixture was right and then pop one of these over the top with the tab in the mid position.
The effect of this is to restrict the movement of the air screw to a 1/4 turn in each direction from the factory setting.
I HAVE NO IDEA WHY THIS WAS IMPORTANT ON THESE CARBS. CAN PADDERS OR GARN OR SOMEONE SHED ANY LIGHT HERE?
Looks like I got you there Guy :wink: :wink: let me know if you have them fitted on your carbs.
If you need the original kawa service manual that shows these and other fiddly bits drop me a pm.
Yep Mark you have me there :oops: i don't have them on my carbs (i think) but the carbs on the 650 are from a Z1000a2.
#449
Z1000A2 Z650B1
GUYZED
#94 PostAuthor: GUYZED » Mon Sep 26, 2011 7:15 pm
WOW :shock: Thanks Dave... that is going to look the dogs when it's polished and i fitted it to the bike...see you at Stafford to pick it up...roll on Stafford.
#449
Z1000A2 Z650B1
mikey
#95 PostAuthor: mikey » Mon Sep 26, 2011 9:08 pm
See you in the que at daves stand guy got to pick mine up as well.
Crofty
#96 PostAuthor: Crofty » Mon Sep 26, 2011 9:21 pm
Went to Wakefield on my ExhaustCraft piper fitted 650 today and have to say the sound was half the fun. I was a bit nervous passing some stationary police cars, but at low revs or cruise mode it seems not to attract any unwarranted attention. It is a different story at 9500rpm.
Pipes need another polish as they are light yellow to collecter box, is this normal? Would vht paint inside help?
have you any engine mods to go with the VM26mm carbs Guy? have wondered this before.
GUYZED
#97 PostAuthor: GUYZED » Mon Sep 26, 2011 9:23 pm
mikey wrote:See you in the que at daves stand guy got to pick mine up as well.
Yep, see you there Mikey...i was speaking to Dave today and he said that he was making you some down pipes.
#449
Z1000A2 Z650B1
GUYZED
#98 PostAuthor: GUYZED » Mon Sep 26, 2011 9:30 pm
Crofty wrote:Went to Wakefield on my ExhaustCraft piper fitted 650 today and have to say the sound was half the fun. I was a bit nervous passing some stationary police cars, but at low revs or cruise mode it seems not to attract any unwarranted attention. It is a different story at 9500rpm.
Thats good to know about the noise level of the pipes Jim (Thanks for that)
It has a 720cc Wiseco kit with Z750 cams and i thought Z1000a2 carbs were 28mm.
#449
Z1000A2 Z650B1
coldsummer
#99 PostAuthor: coldsummer » Mon Sep 26, 2011 9:50 pm
Reckon my pipe must be way down the line then... :cry:
Exhaust Craft
#100 PostAuthor: Exhaust Craft » Mon Sep 26, 2011 10:21 pm
coldsummer wrote:Reckon my pipe must be way down the line then... :cry:
Yours is next Coldsummer,as soon as this one is done,then one for a Z1000
I then need to make at least one for my stand at Stafford,I had planned on two surprises for Stafford but have run out of time sorry guys,they were both for Z900-Z1000's
coldsummer
#101 PostAuthor: coldsummer » Mon Sep 26, 2011 10:39 pm
:sou
GUYZED
#102 PostAuthor: GUYZED » Mon Sep 26, 2011 10:49 pm
:sou
There looks like there's going to be quite a queue at Dave's stand at Stafford with people picking their pipes up :D
#449
Z1000A2 Z650B1
pertonpc
#103 PostAuthor: pertonpc » Tue Sep 27, 2011 5:33 am
Interesting exhaust pics on here Guy
Would like to see what baffle arrangement gets fitted - is it a custom job or a ready made one?
Are they removable to allow re-packing etc.
Wouldn't want to ride behind you with a straight through version :roll:
Although MarkGB on here has got a 900 running a 4:1 which has been "lightened" if you know what I mean - and that sounds ok.
GUYZED
#104 PostAuthor: GUYZED » Tue Sep 27, 2011 5:40 am
I think you with have to ask Dave what the baffle is going to look like as i left it up to him.
#449
Z1000A2 Z650B1
Crofty
#105 PostAuthor: Crofty » Tue Sep 27, 2011 7:17 am
Guy, Not up on the later 1000's, just thought later Z900A4 and Z1000 ad 26 with Z1R getting 28.
Did you get them jetted by trial and error, recommendations or dyno tuning? Crofty
Users browsing this forum: No registered users and 4 guests
