pertonpc wrote:Cheers Ian
It was your post of a few weeks ago that got me thinking about these again - they were missing when I got the 650 and I tried the usual places with no joy. They don't even seem to survive onto breakers yard bikes very often.
These are the same ones as for Z1000 I believe. So scarce I am debating whether to even fit them cos they aren't really that functional are they??
Guy,
They are called limiter caps and they fit over the air screw on the underside of 650/1000 carbs from the factory. I think the idea was to set the air screws so the mixture was right and then pop one of these over the top with the tab in the mid position.
The effect of this is to restrict the movement of the air screw to a 1/4 turn in each direction from the factory setting.
I HAVE NO IDEA WHY THIS WAS IMPORTANT ON THESE CARBS. CAN PADDERS OR GARN OR SOMEONE SHED ANY LIGHT HERE?
Looks like I got you there Guy![]()
let me know if you have them fitted on your carbs.
If you need the original kawa service manual that shows these and other fiddly bits drop me a pm.
Crofty wrote:Went to Wakefield on my ExhaustCraft piper fitted 650 today and have to say the sound was half the fun. I was a bit nervous passing some stationary police cars, but at low revs or cruise mode it seems not to attract any unwarranted attention. It is a different story at 9500rpm.
Pipes need another polish as they are light yellow to collecter box, is this normal? Would vht paint inside help?
have you any engine mods to go with the VM26mm carbs Guy? have wondered this before.
coldsummer wrote:Reckon my pipe must be way down the line then...
Exhaust Craft wrote:coldsummer wrote:Reckon my pipe must be way down the line then...
Yours is next Coldsummer,as soon as this one is done,then one for a Z1000
I then need to make at least one for my stand at Stafford,I had planned on two surprises for Stafford but have run out of time sorry guys,they were both for Z900-Z1000's
coldsummer wrote:Exhaust Craft wrote:coldsummer wrote:Reckon my pipe must be way down the line then...
