carb sync guages
mirror man
carb sync guages
#1 PostAuthor: mirror man » Sun Sep 04, 2011 2:41 pm
hi chaps
has anyone local got a set of carb sync guages that i could borrow :?:
thanks alan
#2 PostAuthor: Pigford » Sun Sep 04, 2011 3:51 pm
I got a good set :wink:
hillbilly
#3 PostAuthor: hillbilly » Sun Sep 04, 2011 7:38 pm
i have a bank of four.(glad i spelt that right)
mirror man
#4 PostAuthor: mirror man » Sun Sep 04, 2011 8:12 pm
thanks lads
hillbilly yur spelins just fine ,not sure after you've had a few beers, thanks for the offer but as mr pigford is a good hundred miles closer im guna take a trip south all being well, mark pm sent
:D :D :D
mikey
#5 PostAuthor: mikey » Sun Sep 04, 2011 9:17 pm
Got a set you can borrow alan
mirror man
#6 PostAuthor: mirror man » Mon Sep 05, 2011 8:25 pm
thanks to mr pigford but after a dash across the other side of the city on the zed [ only got a little wet in the showers] i managed to borrow some gauges from mikey [cheers lads] had to do a little bit of a shop with :rollpin
i just got a chance to connect the gauges about 8ish to night see pic
i think i might check if carb no4 is still on the bike :?: any thoughts lads
#7 PostAuthor: Al » Mon Sep 05, 2011 8:53 pm
Number three is correct i believe at about 22 from memory, numbers one and two have the slides a little open and number four has the slide a little too closed, that is if youre readings are taken from the engine side of the carbs on the vacuum takeoffs' and not from the atmospheric side.
Make sure to reverse the gauges after final set-up to eliminate the possibility of faulty readings. Been tripped up recently by morgan carbtune hoses squashing in under vacuum!
mirror man
#8 PostAuthor: mirror man » Mon Sep 05, 2011 9:36 pm
thanks AL
yes the pipes were connected to the four vacume out lets engine side of carbs, i will be checking the slide heights and also have a little play with some adjustments in the next couple of days , also good advice on reversing the hoses
cheers AL
#9 PostAuthor: Al » Mon Sep 05, 2011 9:53 pm
Al im not too familiar with the early type carbs and the choke arrangements but with mine you can use the vacuum gauges with a cold engine to balance the chokes. Makes starting more of a science and less of a lottery. Raising the question here then; are all the chokes fully home???
Users browsing this forum: Bing [Bot] and 24 guests
