Bottom Yoke Z1/Z1A or Z1B Euro Spec
DogsbolloxofZ1B
#1 PostAuthor: DogsbolloxofZ1B » Wed Aug 24, 2011 6:20 pm
I'm looking for a UK spec bottom yoke with the pre-cast hole for the steering damper, anybody got one:?:
Mike
uk kev
#2 PostAuthor: uk kev » Sun Aug 28, 2011 5:55 pm
Hey Mike my 74 US spec Z1b has the steering damper hole, as I just fitted a damper today.
Sorry I can't help you with your search though.
jacky1962y
hole to take steering damper?
#3 PostAuthor: jacky1962y » Sun Aug 28, 2011 6:44 pm
Should this hole be tapped?, mine is not as i have a nut & bolt connecting the damper.
Jacky
DogsbolloxofZ1B
#4 PostAuthor: DogsbolloxofZ1B » Sun Aug 28, 2011 7:06 pm
Just a clearance hole for an M8 bolt, i.e. Nut & bolt.
Mike
uk kev
#5 PostAuthor: uk kev » Sun Aug 28, 2011 7:14 pm
It is an 8x60 flanged bolt, part number 92001-1581, NLA, fitted with plain washers and a lock nut. :wink:
jacky1962y
Bolt hole
#6 PostAuthor: jacky1962y » Sun Aug 28, 2011 7:24 pm
Thanks gents.
Jacky
bedlow1
#7 PostAuthor: bedlow1 » Tue Aug 30, 2011 6:18 pm
What dogs means I think is that hes looking for a Euro bottom yoke which is rather different to the yankee type.
It has a predrilled hole for the damper but the steering lock underneath is different on a euro yoke, rather than a large round hole and barrel lock the Euro item has a much smaller hole to except the small nieman type lock and key.
Nieman but often has small key without crest
yankee
hillbilly
#8 PostAuthor: hillbilly » Tue Aug 30, 2011 6:39 pm
i have one,but i think its a usa one,as got big hole at front for steering lock.also neds a steering stem in it. :shock:
#9 PostAuthor: z1bman » Tue Aug 30, 2011 7:13 pm
the European steering stem/ bottom yoke is the same as as us spec they are the same part no. as for the steering lock the smaller type lock part no 27016-5009 is for later models from z650 onwards + are designed to fit into the head stock + are secured by a chrome plate which swivels to allow access to the lock
these are the models that it fits
KZ1000-D3 Z1R (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 Custom (1977)
KZ650-C2 Custom (1978)
KZ650-C3 Custom (1979)
KZ650-D1 SR (1978)
KZ650-D1A SR (1978)
KZ650-D2 SR (1979)
KZ650-E1 LTD (1980)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 LTD II (1980)
bedlow1
#10 PostAuthor: bedlow1 » Tue Aug 30, 2011 7:45 pm
Z1Bman
yes well spotted ive made a mistake ( i dug out the later headstock lock set) the key and lock set shown is for the bikes you suggested.
However here is the correct nieman lock set for a Euro bottom yoke and also a pic to show the lock in situ which as you can see is different to the yankee lock arrangement, Our fork assy were 44001-137 z1/A and 44001-163 Z1B and the yanks were 44001-095/44001-136 Z1A and 44001-162 Z1B.
Ive had four UK bikes over the years and they have all had the nieman locks underneath.
The small swivel dust cover and fixing pin is missing so heres a clear shot
#11 PostAuthor: z1bman » Tue Aug 30, 2011 9:17 pm
do you have the part no for the uk spec bottom yoke. this is one for the purists i think
