I'm looking for a UK spec bottom yoke with the pre-cast hole for the steering damper, anybody got one:?:
Mike
Bottom Yoke Z1/Z1A or Z1B Euro Spec
- DogsbolloxofZ1B
				jacky1962y
 - Regular Poster
hole to take steering damper?
Should this hole be tapped?, mine is not as i have a nut & bolt connecting the damper.
Jacky
Jacky
- DogsbolloxofZ1B
				jacky1962y
 - Regular Poster
Bolt hole
Thanks gents.
Jacky
						Jacky
What dogs means I think is that hes looking for a Euro bottom yoke which is rather different to the yankee type.
It has a predrilled hole for the damper but the steering lock underneath is different on a euro yoke, rather than a large round hole and barrel lock the Euro item has a much smaller hole to except the small nieman type lock and key.
Nieman but often has small key without crest
yankee
yankee
						the European steering stem/ bottom yoke is the same as as us spec they are the same part no. as for the steering lock the smaller type lock part no 27016-5009 is for later models from z650 onwards + are designed to fit into the head stock + are secured by a chrome plate which swivels to allow access to the lock
these are the models that it fits
KZ1000-D3 Z1R (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 Custom (1977)
KZ650-C2 Custom (1978)
KZ650-C3 Custom (1979)
KZ650-D1 SR (1978)
KZ650-D1A SR (1978)
KZ650-D2 SR (1979)
KZ650-E1 LTD (1980)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 LTD II (1980)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-D1 SR (1978)
KZ650-D1A SR (1978)
KZ650-D2 SR (1979)
KZ650-E1 LTD (1980)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
Z1Bman
yes well spotted ive made a mistake ( i dug out the later headstock lock set) the key and lock set shown is for the bikes you suggested.
However here is the correct nieman lock set for a Euro bottom yoke and also a pic to show the lock in situ which as you can see is different to the yankee lock arrangement, Our fork assy were 44001-137 z1/A and 44001-163 Z1B and the yanks were 44001-095/44001-136 Z1A and 44001-162 Z1B.
Ive had four UK bikes over the years and they have all had the nieman locks underneath.
The small swivel dust cover and fixing pin is missing so heres a clear shot
