ignition switch
Surfdeneige
ignition switch
#1 PostAuthor: Surfdeneige » Tue May 01, 2007 6:01 pm
can a dodgy ignition switch have an effect on the clean smooth running of all 4 cyl?
A ken fit like!
#2 PostAuthor: Pigford » Tue May 01, 2007 6:47 pm
YES, any dodgy electrical connection could effect spark.
If there's a bit of surging due to poor connection this can make it play up :!:
Corrosion is a favourite, the positive connections can loosen & corrode badly, usually the hidden ones :roll:
#3 PostAuthor: Rich » Tue May 01, 2007 7:27 pm
check your kill switch as well, the springs rust and the connectors bounce as you go along.
bunnysZ
Granny Magnet
#4 PostAuthor: bunnysZ » Tue May 01, 2007 9:23 pm
dodgy ignition switch is the problem i have at the moment , imagine the switch as a clock , key in and 6 oclock is on , now its changed, 5 past 6 is on.
but its not effecting the cyl , just cuts out some times
